Buna ziua,
Imi puteti spune cum se verifica si care este nivelul uleiului hidraulic pentru suspensie?
Multumesc
nivel ulei suspensie reglabila
florindaniel
- Localitate: ploiesti
paulsebastiant
> Now some technical details on checking the fluid level:
> -Checks need to be performed every 20.000km (or 2years)
> -Checks need to be performed with a COLD, STOPPED engine.
> -Checks need to be performed at running height.
> -Level needs to be above -MIN- indicator
> Refill procedure:
> -Put car in low position, fill with LDS to -MAX-. Put Reservoir at
> 0.5bar. (Or ~6PSI) Note, this isn't easy without proper equipment.
> -Start engine, select maximum height, move steering wheel, from
> complete left to complete right and back to center.
> -Stop Engine. Check LDS level (see above)
> -If the level is still below -MIN- add 1L (LDS comes in 1L flasks
and
> 5L tanks)
> And lastly, check maximum level:
> -Cold, Stopped engine, at car at running height:
> -Hydractive 3+ level is not allowed above -HYD- indicator.
> Refill procedure:
and
> 5L tanks)
Total mesaje 187831
Total subiecte 18671
Cel mai nou membru oprean
