verificare serie sasiu
- Localitate: Alba Iulia
- Masina: Citroen C5 1997 cmc 120 kw
- 2: Nu
- 3: Nu
Re: verificare serie sasiu
Va rog o verificare:VF7RDRHHAAL553959.
Mulțumesc!
Mulțumesc!
- Localitate: Campina / Bucuresti
- Masina: Citroen C2 VTS (de competitie)
- 2: Lexus CT200H (de familie)
Dinis Florin scrie:Va rog o verificare:VF7RDRHHAAL553959.
Mulțumesc!
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 12310 CJ 1 0368
Data de Inceput de Garantie DDG 20.08.2010
Numar de Serie al Motorului 10 DYXS 4002063
OPB H007
NRE e2*2001/116*0360*12
P4A 9665460399
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI KGN - VOPSEA BOURRASQUE
TIP ECHIPARE INTERIOARA PIELE CLAUDIA MATINAL L019 "XT"
CULOARE GARNISAJ "FC"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C1
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE EXCLUSIV
MONOGRAMA C5
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATE DE PUTERE (MOTOR) PUTERE 120 KW 340 NM
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE CU FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC COMANDA INTEGRATA 220W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
AMBREIAJ FARA AMBREIAJ
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA DE RETROVIZOR EXTERIOR CROMATA ELECTROCHIMIC
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON TRAPA DE PLAFON CU COMANDA ASISTATA SECVENTIALA + SISTEM ANTIPRINDERE
ORNAMENT DE BARA DE PROTECTIE ORNAMENT CENTRAL SPATE CROMAT
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA SOFT
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE ANODIZATA SOFT
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU HALOGEN
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DEV
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
RECEPTOR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
MODUL TELEMATIC MODUL TELEMATICA AUTONOM
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 6+
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
Servicii Diagbox: Activari/dezactivari optiuni / Actualizari software / Telecodare cheie noua/Reparatii chei telecomanda PSA / Telecodare RD/RT CD/Mp3 / Diagnoza pre-achizitie auto
- 2: Nu
- 3: Nu
Mulțumesc frumos!
- Localitate: Timisoara
Salut
Mi-am luat si eu de curand un Citroen C5.
Maa jutati va rog si pe mine cu informatiile tehnice conform seriei de sasiu?
Multumesc!!!
VF7RD9HL0DL519511
Multumesc!!!
VF7RD9HL0DL519511
alwaysfresh scrie:Salut
Multumesc!!!
VF7RD9HL0DL519511
Nr. APV/PR 13457 CJ 1 0157
Data de Inceput de Garantie DDG 25.09.2013
Numar de Serie al Motorului 10 JBEU 0002726
OPB H00A
NRE e2*2001/116*0360*29
P4A 9803166899
Informatii generale
NIVEL DE ECHIPARE INALTIME MEDIE PLUS
MOTOR DIESEL TURBO DV6C
TRANSMISIE CUTIE DE VITEZE MANUALA5
TIP DE VOPSEA METALIZATA IN TREI STRATURI SIDEF
CULOAREA CAROSERIEI KWE - VOPSEA ALB SIDEFAT
TIP ECHIPARE INTERIOARA TESATURA BRISE + OMNI SERGE ’6M’
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
EVOLUTIE DEFINITIE TEHNICA ANIMATIE GAMA
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
MONOGRAMA C5
Alimentare motor
CATALIZATOR CATALIZATOR CU MAI PUTIN DE 50PPM
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DISPOZITIV (ANTIPOLUARE) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
CUPLU RAPORT CP 17 X 73
STIL ROATA (JANTA) ROATA STIL IROISE "16 INCI"
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 84
JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/60 R16 98V NERANFORSAT
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 184
SUSPENSIE ACTIVA FARA SUSPENSIE HIDRACTIVA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
LUMINA DE PRAG LUMINI DE PRAG FATA
ROATA DE REZERVA FARA ROATA DE REZERVA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU CALD
LUMINI INTERIOARE DIVERSE ILUMINAT STANDARD + LUMINA DE CITIT RAND2
CAPITONAJ DE USA DECORATIE ALUMINIU CALD SOFT
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) FARA COTIERA FATA
AFISAJ AFISAJ DEV DE INALTA REZOLUTIE
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA BURDUF/MANER MANETA + PLACUTA DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE DIN ALUMINIU CULOARE CALDA
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUPORT LOMBAR MANUAL
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB + BLUETOOTH
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
BATERIE BATERIE L3 720 LDC(L3 720 70AH EF 720 EN)
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SOCIETATE (OVSA)
ETICHETA FARA
RULARE DRUM CORECT
- Localitate: Iasi
- Masina: Citroën C5 III 2.0 HDI
As dori o verificare daca se poate, VF7RDRHA4FL505034.
Multumesc!
Multumesc!
sebastian9415 scrie:Salut,
Multumesc!
Nr. APV/PR 14045 CJ 1 0133
Data de Inceput de Garantie DDG 29.04.2015
Numar de Serie al Motorului 10 DYZE 4137985
OPB H00K
NRE e2*2001/116*0360*32
P4A 9811533899
Informatii generale
MOTOR DIESEL DW10C FAP 103KW
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP ECHIPARE INTERIOARA TESATURA FYBER + OMNI SERGE "10"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MONOGRAMA C5
Alimentare motor
CILINDREE 2000 CM3
CUPLU RAPORT RAPORT PUNTE 17 X 71
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
CUTIE DE VITEZE TIP ML6C
MIRROR LINK FARA OGLINDA LINK
ECHIPAMENT PLANSA DE BORD DECORATIUNE TUNGSTEN
CAPITONAJ DE USA DECORATIUNE TUNGSTEN
WIFI FARA WIFI
VOLANT VOLAN PIELE CU 4 BRATE DECOR TUNGSTEN
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
Diverse
ETICHETA FARA
RULARE DRUM CORECT
- Localitate: dambovita
va salut, as dori o verificare daca se poate pt aceasta serie VF7RWRHRJ54095677 vreau sa o cumpar dar imi este frica pt ca are cutia automata, un sfat va rog, va multumesc
cata_besst scrie:va salut, as dori o verificare daca se poate pt aceasta serie VF7RWRHRJ54095677 vreau sa o cumpar dar imi este frica pt ca are cutia automata, un sfat va rog, va multumesc
Nr. APV/PR 11700 CJ 1 0443
Data de Inceput de Garantie DDG 22.12.2008
Numar de Serie al Motorului 10 DYXG 4001204
OPB HBDA
NRE e2*2001/116*0360*04
Informatii generale
TIP CAROSERIE BREAK 5 USI
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TIP ECHIPARE INTERIOARA PIELE CLAUDIA MISTRAL L019 "QR"
MONOGRAMA C5
Alimentare motor
DEPOLUARE (MOTOR) DEPOLUARE MOTOR EURO 4
CILINDREE 2000 CM3
VARIATE DE PUTERE (MOTOR) PUTERE 100 KW 320 NM
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 160W
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION CU GEAM DE PAVILION
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
CAPITONAJ DE USA DECORATIUNE NEGRU ARGINT STRALUCITOR
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
BECURI DE PROIECTOR LAMPA CU DESCARCARE
AFISAJ AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO SISTEM RADIOTELEFON "RT4"
AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
Electricitate
BATERIE BATERIE L3 500
Diverse
ETICHETA FARA
ECHIPAMENT DE PRIM AJUTOR RECIPIENT SUB PRESIUNE REPARARE PNEU
RULARE DRUM CORECT
buna ziua va deranjez din nou imi puteti spune dotarile acestei masini ms VF7RWRHRJ54052812.
va multumesc
va multumesc
- Localitate: Gherla
Din cate vad nu se mai poate verifica nimic in Servicebox fara sa platesti
- Localitate: CALAFAT
- Masina: Citroen C5 Exclusive
- 2: nu
- 3: nu
Buna ziua! Mă poate ajuta cineva cu dotările pentru un DS5 seria VF7KFAHVMHS192329. Vreau sa o iau la licitație din Belgia și nu prea are poze și detalii despre dotări. Mulțumesc!
- WLD
- Admin CITROclub
- Masina: BX 16v '88 si 89
- 3: Xsara 2.0hdi stage 1+
Nu se mai poate. De cateva luni, PSA permite accesul la informatii numai pe baza unui abonament.
- 2: nu
- 3: nu
Am inteles! Mulțumesc!
- Localitate: Sibiu
- Masina: Citroen C4
Salu.
Ma poate ajuta cineva cu informatii despre masina cu urmatoarea serie de sasiu : VF7XDRHH8AZ052681 ?
Multumesc anticipat.
Total mesaje 187776
Total subiecte 18654
Total membri 11816
Cel mai nou membru Jamesitats
