Pagina 1 din 1
nivel ulei suspensie reglabila
Scris: Vin 09-Ian-2015 11:02
de florindaniel
Buna ziua,
Imi puteti spune cum se verifica si care este nivelul uleiului hidraulic pentru suspensie?
Multumesc
Scris: Vin 09-Ian-2015 21:16
de Eddyson
Din ce stiu eu, nivelul uleiului ptr. suspensie se verifica cu masina pe o suprafata plana, se lasa la nivelul minim al suspensiei si se verifica nivelul uleiului in rezervorul acestiua.
Nivelul optim ar trebui sa fie in dreptul micii site care se vede in momentul desfacerii capacului
Scris: Vin 09-Ian-2015 22:42
de paulsebastiant
> Now some technical details on checking the fluid level:
> -Checks need to be performed every 20.000km (or 2years)
> -Checks need to be performed with a COLD, STOPPED engine.
> -Checks need to be performed at running height.
> -Level needs to be above -MIN- indicator
> Refill procedure:
> -Put car in low position, fill with LDS to -MAX-. Put Reservoir at
> 0.5bar. (Or ~6PSI) Note, this isn't easy without proper equipment.
> -Start engine, select maximum height, move steering wheel, from
> complete left to complete right and back to center.
> -Stop Engine. Check LDS level (see above)
> -If the level is still below -MIN- add 1L (LDS comes in 1L flasks
and
> 5L tanks)
> And lastly, check maximum level:
> -Cold, Stopped engine, at car at running height:
> -Hydractive 3+ level is not allowed above -HYD- indicator.
Scris: Sâm 10-Ian-2015 10:50
de Eddyson
Intrebare:
Daca masina e la Running Height ... nu e sub presiune sistemul hidraulic, ceea ce ar face problematica desfacerea capacului rezervorului ?
Chiar si cu motorul oprit.
