Se pot afla emisiile de noxe (masina noua) dupa VIN ?
sirJohn
Mesajde sirJohn » Vin 15-Mar-2013 11:49
As fi interesat sa stiu daca pe baza VIN-ului se poate afla cantitatea de noxe emise (g/km) la data fabricatiei.
Multumesc anticipat.
Mesajde dj01fad » Vin 15-Mar-2013 12:18
se poate afla norma de poluare. pune seria aici.
Mesajde mbc » Vin 15-Mar-2013 14:53
C5 - 2 2.0 HDI de 138 de cai emite 158g / KM.
sirJohn
Mesajde sirJohn » Sâm 16-Mar-2013 01:00
dj01fad scrie:se poate afla norma de poluare. pune seria aici.
VF7RCRHRG76788111
urzica
Localitate: Medgidia
Mesajde urzica » Sâm 16-Mar-2013 10:45
Caracteristicile vehiculului
Linie de produs C5 II
Nr. APV/PR 10934 CJ 1 0298
Data de Inceput de Garantie DDG 11.01.2007
OPB A03Z
NRE e2*2001/116*0306*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION MEDIE INALTA
MOTEUR DIESEL TURBO DW10BTED4 FARA FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EFB - VOPSEA GANACHE
TYPE D’HABILLAGE INTÉRIEUR TESATURA SHOW "SM"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA OLYMPOS 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA AC 3300I
JOINT COTÉ PONT GARNITURA PE PARTEA PUNTII AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X16 W
ROUE (TYPE) MONTARE ROATA ALIAJ 3
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) TIP OLYMPOS
FEU D’ÉCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
PACK LOOK EXTÉRIEUR PACHET LOOK EXTERIOR IN CULOAREA CAROSERIEI
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE CUBIC CU OCHIURI MICI
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN POLIPROPILENA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
TUNER-RADIO CU UN SINGUR TUNER RADIO
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
PACK RADIO / INFORMATION / COMMUNICATION RD4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRÉQUENCE RADIO FRECVENTA RADIO ASIA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
andreiandy333
Localitate: Ploiesti
Mesajde andreiandy333 » Sâm 16-Mar-2013 12:26
Îmi poþi spune Urzicã ce site ai accesat pentru a vedea toate caracteristicile maºinii dupã ViN?
mesersmith
Moderator - C5
Localitate: calarasi
Masina: C5 III
2: C5 II
3: Peugeot 308
Mesajde mesersmith » Sâm 16-Mar-2013 12:42
urzica
Mesajde urzica » Sâm 16-Mar-2013 12:56
andreiandy333 scrie:Îmi poþi spune Urzicã ce site ai accesat pentru a vedea toate caracteristicile maºinii dupã ViN?
Cum a spus si Messersmith trebuie sa-ti faci cont pe citroen service.com.
sirJohn
Mesajde sirJohn » Sâm 16-Mar-2013 16:15
Multumesc Urzica pentru toate aceste detalii.
Imi poti spune te rog si care este emisia de noxe la acest VIN ?
mesersmith
Moderator - C5
Masina: C5 III
2: C5 II
3: Peugeot 308
Mesajde mesersmith » Sâm 16-Mar-2013 16:42
157 CO2 g/km
sirJohn
Mesajde sirJohn » Sâm 16-Mar-2013 17:03
mesersmith scrie:157 CO2 g/km
Merci mult Mesersmith.
Mesajde mbc » Sâm 16-Mar-2013 17:46
Ma simt invizibil, dar e ok.
sirJohn
Mesajde sirJohn » Sâm 16-Mar-2013 22:09
mbc scrie:Ma simt invizibil, dar e ok.
mbc - trebuie sa-mi cer scuze : nu esti invizibil, ci am citit eu gresit (C5 2.2 HDi in loc de C5 II 2.0 HDi). Am revazut postul tau acum si iti multumesc pentru precizare.
Un weekend placut in continuare!
mesersmith
Moderator - C5
Masina: C5 III
2: C5 II
3: Peugeot 308
Mesajde mesersmith » Dum 17-Mar-2013 11:48
Sa stiti ca si eu am citit la fel: 2.2
Ba mai mult, eu chiar am cautat si motorul asta, dar nu am reusit sa-i aflu noxele, va dati seama... :razz: :razz: :razz:
Abia acum cand ati spus voi ca e scris 2.0 mi-am dat seara recitind. Pffff...
andreiandy333
Mesajde andreiandy333 » Mie 20-Mar-2013 21:07
Multumesc mesersmith si urzica.Sa traiti sanatosi. :)
Înapoi la “Citroen C5 I-II”
Utilizatori ce ce navighează pe acest forum: Niciun utilizator înregistrat și 11 vizitatori
    Total mesaje 187776
    Total subiecte 18654
    Total membri 11819
    Cel mai nou membru Tudoo
