Salut baieti,
Ma poate ajuta si pe mine cineva cu toate datele tehnice la c5-ul meu.
VIN : vf7dc4hxb76076509 Stiu ca se intra pe service/citroen si iti arata acolo multe detalii. Nu reusesc sa imi fac cont.
Multumesc anticipat.
Date tehnice dupa VIN
claudiu1984
- Localitate: Constanta
- urzica
- Localitate: Medgidia
Caracteristicile vehiculului
Linie de produs C5
Nr. APV/PR 08950 CJ 1 0180
Data de Inceput de Garantie DDG 31.05.2001
OPB R00E
NRE e2*98/14*0221*00
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5
SILHOUETTE BERLINA CU 5 USI
FINITION INALTA MEDIE
MOTEUR DIESEL TURBO DW12TED4
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE VOPSEA ALBASTRU LEMAN
TYPE D’HABILLAGE INTĂRIEUR VELUR RIZIERE "HZ"
COULEUR DE GARNISSAGE "FT"
BOITE DE VITESSES (CARACTĂRISTIQUES) CUTIE DE VITEZE MANUALA ML5T
MOTEUR (TYPE) MOTOR TIP EW/DW
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE FARA C T
Alimentare motor
BOĂTIER PAPILLON (ADMISSION AIR MOTEUR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
DĂTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DĂPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RĂCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLUARE TEHNICA VEHICUL L4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 500W
VARIANTE ASSOCIĂE INJECTION SISTEM DE INJECTIE BOSCH
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 67
STYLE ROUE ROATA ALIAJ IMOLA 15 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC CU COMANDA ASISTATA
JOINT COTĂ ROUE GARNITURA LATERALA DE ROATA AC 3300I
JOINT COTĂ PONT GARNITURA PE PARTEA PUNTII AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205X65X15 H
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA ML
Suspensie Directie Franare
ANTIPATINAGE FARA SISTEM ANTIPATINARE
COURSE MĂCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 148
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3 PLUS
CONTRĂLE DYNAMIQUE DE STABILITĂ CU SISTEM ESP
Caroserie Echipamente
ENJOLIVEMENT LATĂRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN CULOAREA CAROSERIEI
ENJOLIVEMENT LATĂRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
FEU D’ĂCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT CALANDRU SEMIINCHIS + SCUT DESCHIS
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA ALIAJ + PNEU STANDARD
ACCESSOIRES EXTĂRIEURS RETROVIZOR SI MANER EXTERIOR IN CULOAREA CAROSERIEI + GUSEU VOPSIT
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
Echipament de interior
PACK AMBIANCE FARA PACHET AMBIANTA
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
RADIO-TĂLĂPHONE PREGATIRE PRELIMINARA PENTRU RADIO TELEFON (ANTENA + CABLU)
GRADUATION VITESSES GRADATIE IN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD FARA DECORATIUNE DIN LEMN SAU ALUMINIU
GARNISSAGE VOLUME CHARGEMENT COVORAS DE PORTBAGAJ CARE NU ESTE REVERSIBIL
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
HAUT-PARLEUR MONTARE 4 DIFUZOARE + 2 TWEETERE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RĂGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORT REGLARE LOMBARA CONDUCATOR
ELĂMENTS DE GARNISSAGE INTĂRIEUR ELEMENTE DE TAPITERIE INTERIOARA CU TESATURA
ACCOUDOIR ASSISE AVANT MONTARE FARA COTIERA FATA
COMPACT DISQUE FARA MONTARE COMPACT DISC
BOITE DE RANGEMENT FARA CONTAINER DE DEPOZITARE
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE ECRAN MONOCROM
CD ROM POUR AUTO PC FARA CD ROM PENTRU AUTO-PC
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFFICHEUR AFISAJ (RADIO + CEAS, T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RĂCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD2"
RĂFRIGĂRATION SISTEM DE REFRIGERARE AUTOMATA
RĂGULATEUR DE VITESSES SISTEM DE REGULARIZARE VITEZA
RĂTROVISEUR INTĂRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
DĂTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
AMPLI-ĂQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L3 450
DĂMARREUR DEMAROR CLASA 6
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRĂQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ROULAGE DRUM CORECT
TRIANGLE DE PRĂSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
Linie de produs C5
OPB R00E
Informatii generale
LIGNE DE PRODUIT C5
Alimentare motor
CARBURANT MOTORINA
Electricitate
Diverse
ROULAGE DRUM CORECT
Total mesaje 187859
Total subiecte 18685
