Salutare colegi,
astazi am pus interfata pe masina si surpriza, o gramada de erori adunate.
1. BSI: * Permanent Fault
Communication fault with the alarm ECU
2. Control Pnel: * Remote fault
Intermittent fault
Engine speed value received incorrect
* Remote fault
Intermittent fault
Coolant temperature value received incorrect
* Remote fault
Intermittent fault
Vehicle speed value received incorrect
3. Injection: * Temporary fault
Turbo Pressure signal. supply short circuited to pozitive or to earth
* Temporary fault
Crankshaft- camshaft synchronising. Camshaft sensor supply short circuited to positive
* Temporary fault
Accelerator pedal 1 signal. suplly short circuited to positive or to earth
* Temporary fault
Sensor power supply. Short circuit to positive
3. Suspension: * Remote fault
Intermittent fault
Data invalid from engine ECU value received incorrect
4. Switch module at the sterring wheel: * Permanent fault
Lightning control incoherence
astea ar fi erorile citite. Ma poate ajuta cineva la identificarea lor?
Multumesc anticipat.
Cateva erori
- urzica
- Localitate: Medgidia
Re: Cateva erori
Astea nu sunt cateva erori, cred ca este de la baterie, acum iarna scade capacitatea bateriei iar la pornre avand bateria slaba calculatoarele o iau razna. sterge erorile si urmareste mai des cand apar si conditiile in care apar.
Iar toate erorile trebuie sa aiba un cod care se citeste cu dignoza.
PS. Un pont... cauta dupa codul erorii pe internet si vei afla o multime de lucruri bune despre masina ta.
http://www.fileshare.ro/e3172456246
http://www.fileshare.ro/e3172456248
- picieri
- Localitate: Ludus
- Masina: C5-I 2002 80KW 2.0HDI
- 2: Corsa D 2007 60KW 1.2
Re: Cateva erori
Bateria este noua, cumparata in decembrie.
Am sters erorile dar a doua zi reapar.
Unde pot gasi codurile de eroare in lexia?
Multumesc mult de ajutor.
- MARIAN
- Admin CITROclub
- Localitate: Buzau
- Masina: Xantia 1.9TD VSX
- 2: C5 2.0 HDI 110CP
Re: Cateva erori
La motor ai ceva probleme cu unul sau mai multe fire/conexiuni, la COM este o problema cu maneta de la faruri, iar celelalte sunt coduri fantoma (daca nu sunt anomalii in funcționare).
- picieri
- Localitate: Ludus
Re: Cateva erori
MARIAN scrie:La motor ai ceva probleme cu unul sau mai multe fire/conexiuni, la COM este o problema cu maneta de la faruri, iar celelalte sunt coduri fantoma (daca nu sunt anomalii in funcționare).
Poti fi un pic mai explicit cu firele de la motor?
Mai am un com o sa il schimb sa vad daca dispare aceea eroare.
Multumesc mult.
- MARIAN
- Admin CITROclub
- Localitate: Buzau
Re: Cateva erori
Ca sa fiu mai explicit îmi trebuie mașina pentru măsurători suplimentare.
- picieri
- Localitate: Ludus
Re: Cateva erori
Din pacate distanta dintre noi este prea mare.
Oricum iti multumesc mult pentru timpul acordat.
Utilizatori ce ce navighează pe acest forum: Niciun utilizator înregistrat și 27 vizitatori
- Cauta in forum
- Mesaje
- PARTENERI
- Link-uri utile
- Statistici
Total mesaje 187760
Total subiecte 18621
Posts per day: 24
Users per day: 2
Total membri 11707
Cel mai nou membru catalinos
