PHONE IN CITROEN C4 AN 2007....
cum schimbam un bec, cum dam bara jos si multe altele - fara a apela la service
mrk2012
Localitate: ROMANIA
Mesajde mrk2012 » Mie 21-Noi-2012 21:18
SALL AM SI IO NEVOIE NEAPARAT DE AJUTOR AM UN CITROEN C4 AN 2007 SI LA CASETOFONUL ORIGINAL DIN FABRICA LA SETARI PRIN EL IMI SCRIE PE DISPLAY ----PHONE IN---- NU INTELEG CE INSEAMNA LA CE SE REFERA...DAK ATI PUTEA SA MA AJUTATI AS FII FOARTE RECUNASCATOR...MULTUMESC... :razz: :razz:
joeadrianblack
Localitate: Oradea
Mesajde joeadrianblack » Mie 21-Noi-2012 22:17
cu mare placere... vezi ca ti-a ramas CapsLock-ul de la tastatura "pornit"...
beau cand sunt singur sau cand am cu cine...
Rica
Moderator - Bazar
Localitate: Birmingham
Masina: Peugeot 407 SW
Mesajde Rica » Joi 22-Noi-2012 12:13
si fara scurtaturi tip mess :twisted:
Ce ciudat!
MikePop
Localitate: Slatina, Olt
Mesajde MikePop » Joi 22-Noi-2012 13:55
Pai ori are bluetooth ori are vreo mufa in spate ca sa legi vreun handsfree...
Zambeste! Maine poate fi mai rau.
Rica
Moderator - Bazar
Mesajde Rica » Joi 22-Noi-2012 13:56
baga seria masinii si vedem ce dotari are
asa e cel mai simplu si sigur daca nu stii dotarile masinii
Ce ciudat!
mrk2012
Localitate: ROMANIA
ok uite seria..
Mesajde mrk2012 » Joi 13-Dec-2012 17:29
sper sa ma lamureestii....VF7LCNFUC74570568
mersii astept raspuns
MikePop
Mesajde MikePop » Vin 14-Dec-2012 03:13
Informations gĂŠnĂŠrales
GENRE DE PRODUIT
VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE
CITROEN
LIGNE DE PRODUIT
C4
SILHOUETTE
BERLINE 5PTES
FINITION
SX VTR
MOTEUR
INJECTION TU5JP4
TRANSMISSION
BVM5
TYPE DE PEINTURE
PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE
KCW - PEINTURE SABLE DE LANGRUNE
TYPE D’HABILLAGE INTÉRIEUR
VELOURS COTTA + POINTIL "SQ"
COULEUR DE GARNISSAGE
"FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES)
BVM MA5 / N
MOTEUR (TYPE)
MOTEUR TYPE TU/TUD
MONOGRAMME COMPLÉMENTAIRE, DIVERS
SANS MONOGRAMME COMPLEMENTAIRE
CaractĂŠristiques vĂŠhicule
FINITION
SX VTR
TYPE DE PEINTURE
COULEUR DE CAISSE
"FZ"
BVM MA5 / N
Alimentation moteur
MOTEUR
INJECTION TU5JP4
ALIMENTATION
INJECTION "PRIM"
DÉTECTEUR D’EAU FILTRE À GAZOLE
SANS DETECTEUR EAU FILTRE GASOIL
CARTER CYLINDRE (MATIÈRE)
CARTER CYLINDRE FONTE
CARBURANT
ESSENCE SANS PLOMB
DÉPOLLUTION (MOTEUR)
DEPOLLUTION EURO 4(MOTEUR)
MOTEUR (TYPE)
MOTEUR TYPE TU/TUD
CYLINDRÉE
1600 CM3
CATALYSEUR
CATALYSEUR 3 COMPOSES FILTRES IMPR RHODIUM+PALLADI
REFROIDISSEMENT D’HUILE
SANS ECHANGEUR EAU/HUILE
MOTEUR REFROIDISSEMENT
RADIATEUR EP:18 - 21 DM2 TP
RÉCHAUFFAGE CIRCUIT GAZ CARTER
SANS RECHAUFFAGE CIRCUIT GAZ CARTER
AUTODIAGNOSTIC EOBD
AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
DÉPOLLUTION TECHNIQUE VÉHICULE
DEPOLLUTION TECHNIQUE VEHICULE EURO 4
FILTRE À PARTICULE
SANS FILTRE A PARTICULES
VENTILATEUR
1 VENTILATEUR 2 VITESSES 60WAERO
RÉCUPÉRATION DES VAPEURS D’ESSENCE
RECUP VAPEUR ESSENCE PILOTE
VARIANTE ASSOCIÉE INJECTION
SYSTEME INJECTION BOSCH
FILTRE RÉSERVOIR
FILTRE RESERVOIR INTERIEUR
BoĂŽte de vitesses Transmission
TRANSMISSION
BVM5
BVM MA5 / N
COUPLE RAPPORT
CP 13 X 61
STYLE ROUE
ROUE TOLE 16 POUCES
EMBRAYAGE
EMBRAYAGE HYDRAULIQUE
TYPE DE BOITE DE VITESSES (HOMOLOGATION)
TYPE BV MA/5 N
DIFFÉRENTIEL (BOITE)
DIFFERENTIEL 77
PNEUMATIQUE (DIMENSIONS, TYPE)
PNEU 205/55 R16 V NON RENFORCE
ROUES MONTÉES
ROUE 6 POUCES 1/2
ROUE (TYPE)
MONTAGE ROUE TOLE NIV 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE
SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE
BVM MA
Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE
BARRE ANTI DEVERS AR DIAM 27
COLONNE DIRECTION
COLONNE DE DIRECTION REGLAGE MANUEL
ANTIDÉVERS AVANT
BARRE ANTI DEVERS AV DIAM 22
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION
SANS REFROIDISSEMENT HUILE POMPE DIRECTION
SUSPENSION
SUSPENSION NORMALE
CONTRÔLE DYNAMIQUE DE STABILITÉ
SANS SYSTEME ESP
VARIANTE ASSOCIÉE FREIN
ABS BOSCH 8 1
DIRECTION (FONCTIONNEMENT)
DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
PÉDALIER (TYPE)
PEDALIER STANDARD
Carrosserie Equipements
AVERTISSEURS
AVERTISSEUR STANDARD
ANTENNE
ANTENNE PAVILLON COURTE
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE
MONTAGE AVEC DEFLECTEUR AR SUPERIEUR VOLET
DÉCORATION (PEINTE)
DECOR TEINTE MASSE
ENJOLIVEMENT LATÉRAL (ASPECT)
PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEMENT LATÉRAL (DIMENSION)
SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE)
STYLE AZZANA 8 AJOURS 16 POUCES
FEU DE RECUL
AVEC 1 FEU RECUL
FEU D’ÉCLAIRAGE DE SEUIL
SANS FEU ECLAIRAGE DE SEUIL
COMPLÉMENT DE PROTECTION (SOUS MOTEUR)
SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
ETANCHÉITÉ AÉRODYNAMIQUE
SANS JOINT CAPOT AV
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR
RETRO EXT RABATTABLE MANUEL
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT
SANS ENJOLIVEUR SORTIE ECHAPPEMENT
INSONORISATION COTÉ MOTEUR
SANS INSONORISATION
ESSUIE-VITRE AVANT
ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE
ESSUIE-VITRE AR
ESSUIE-PROJECTEUR
SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT
SANS OBTURATEUR FACE AV
VITRE PAVILLON
SANS VITRE PAVILLON
VITRE VOLET ARRIÈRE
VITRE VOLET AR FIXE
PARE-CHOCS
PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
PARE-BOUE (BAVETTE)
AVEC BAVETTES AR
PLAQUE POLICE
SANS PLAQUE POLICE
PORTE-BAGAGES
MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD
PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS
ROUE TOLE REDUITE+PNEU NON STD
ACCESSOIRES EXTÉRIEURS
POIGN EXT+PIED+CDE AR NEUTRE RETRO COUL CAISSE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR)
GLACE RETRO EXT BOMBE
TOIT OUVRANT
TOIT FIXE
ENJOLIVEMENT PARE-CHOCS
BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (ASPECT)
TEINTEE
VITRE (TYPE)
P-B FEUILL + LAT ET AR TREMPE
ACCÈS ET DÉMARRAGE MAINS LIBRES
SANS ACCES ET DEMARRAGE MAINS LIBRES
Equipement intĂŠrieur
ALARME ANTIVOL
SANS ALARME ANTIVOL
ALLUME-CIGARE
ALLUME CIGARE AVANT
APPUI-TÊTE ARRIÈRE
APPUI TETE AR REGLABLE
APPUI-TÊTE AVANT
APPUI-TETE AV REGLABLE
ASSISE ARRIÈRE
COUS SEPA RABATTBLE + DOSS SEPA RABATTABLE
ACCOUDOIR ASSISE ARRIÈRE
SANS ACCOUDOIR AR
CEINTURE DE SÉCURITÉ ARRIÈRE
CEINT SECU AR 3 ENROULEURS 3 PTS
CEINTURE DE SÉCURITÉ AVANT
CEINTURE PYROTECHNIQUE AVEC ALARME
CLIMAT (TEMPÉRATURE AMBIANTE)
PAYS FROIDS
CONDAMNATION ENFANT
CONDAMNATION ENFANT MANUELLE AR
GRADUATION VITESSES
GRADUATION EN KM/H
COMPTE-TOURS
COMPTE-TOURS NUMERIQUE
COTÉ DE CONDUITE (POSTE DE CONDUITE)
CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL
SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD
PL/BORD MISTRAL FACADE INF+PTE CRAYON NEUTRE
FUX INT. DIVERS
PLAFONNIER AV 3 POSITIONS
COMBINÉ (CARACTÉRISTIQUES)
COMBINE NUMERIQUE FACADE GRIS LION
GARNISSAGE DE PORTE
PANNEAU DE PORTE SANS DECOR CHROME SATIN
HAUT-PARLEUR
4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO
CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT)
SANS RIDEAU PARE-SOLEIL
REHAUSSE ASSISE AVANT PASSAGER
SANS REHAUSSE ASSISE AV PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR
CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER
CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR
SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER
SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR
SANS RABATTEMENT ASSISE AV CONDUCTEUR
RABATTEMENT ASSISE AVANT PASSAGER
SANS RABATTEMENT ASSISE AV PASSAGER
ACCOUDOIR ASSISE AVANT
ACCOUDOIR CENTRAL
COMPACT DISQUE
SANS MONTAGE COMPACT DISQUE
BOITE DE RANGEMENT
SANS BOITE DE RANGEMENT
SYSTÈME DE NAVIGATION
SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS
LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE
LEVE-VITRE AR CDE MANUELLE
LECTEUR D’INFORMATIONS ROUTIÈRES
SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR
AFFICHEUR (RADIO+MONTRE+ET OU T°,CD) SANS MEMOIRE
MIROIR DE COURTOISIE
CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
INDICATEUR D’HUILE
RECEPTEUR NIVEAU HUILE
MONTAGE APPUI-TÊTE ARRIÈRE
MONTAGE 3 APPUI-TETE AR
NAPPE CHAUFFANTE
SIEGE NON CHAUFFANT
SAC GONFLABLE LATÉRAL AVANT
SAC GONFLABLE LATERAL THORAX + RIDEAU
SAC GONFLABLE PASSAGER
SAC GONFLABLE COTE PASSAGER
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT)
ANTI PINCEMENT CONDUCTEUR + PASSAGER
PACK ÉQUIPEMENT
SANS PACK EQUIPEMENT AUTO-ECOLE
RETRO EXT CHAUFFANT
NEUTRALISATION COUSSIN GONFLABLE
NEUTRALISATION MANUELLE COUSSIN GONFLABLE
COMMANDE INTÉRIEURE DE PORTE (ASPECT)
COMMANDE INTERIEURE PORTE ASPECT NEUTRE
PLANCHER ARRIÈRE CHARGE
SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE
REGLAGE MANUEL A DISTANCE PROJECTEURS
PROTECTION POSTE AVANT
SANS PROTECTION POSTE AV
PARE-SOLEIL AVANT
COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
RANGEMENT (POSTE CONDUITE)
RANGEMENT LAT FERME SANS LUNETTE
RÉCEPTEUR RADIO
SYSTEME AUDIO COMPACT DISC RDS "RD4"
RÉFRIGÉRATION
REFRIGERATION AUTOMATIQUE
RÉGULATEUR DE VITESSES
REGULATEUR ET LIMITEUR VITESSE
REHAUSSE ASSISE AVANT CONDUCTEUR
REHAUSSE CONDUCTEUR REGLAGE PARALLELE
RÉTROVISEUR INTÉRIEUR
RETROVISEUR INT JOUR - NUIT NON ELECTROCHROME
SURTAPIS (ASPECT)
SANS SURTAPIS
SAC GONFLABLE CONDUCTEUR
SAC GONFLABLE COTE CONDUCTEUR
RANGEMENT VOLUME CHARGEMENT
AVEC FILET + RANGEMENT AMOVIBLE DANS COFFRE
TAPIS
MOQUETTE AIGUILLETEE DILOUR F550
TUNER-RADIO
MONO TUNER RADIO
PROTECTION INTÉRIEURE
SANS PROTECTION INTERIEURE
DÉTECTION D’OBSTACLE
SANS DETECTEUR OBSTACLE
STORES LATÉRAUX
SANS STORES LATERAUX
ADAPTATION GARNITURE
SOUFFLET + POMMEAU STD PASTILLE CHROME
SURTAPIS
SANS SURTAPIS
AMPLI-ÉQUALISEUR
SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE
VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VITRE (TYPE)
VOLANT
VOLANT MOUSSE 2 BRAS
VENTILATEUR
RÉTROVISEUR INTÉRIEUR SURVEILLANCE ENFANT
SANS RETROVISEUR INTERIEUR SURVEILLANCE ENFANT
ElectricitĂŠ
ALTERNATEUR
ALTERNATEUR CLASSE 8+
AVERTISSEURS
BATTERIE
BATTERIE L2 400
DÉMARREUR
DEMARREUR CLASSE 3
ECLAIREMENT PARTICULIER
SANS ECLAIRAGE PARTICULIER
FEU DE RECUL
AVEC 1 FEU RECUL
FEUX INT. DIVERS
LAMPE HALOGENE
MULTIPLEXAGE
MONTAGE MULTIPLEXE CAN CAN
Marques d'ĂŠquipements
ABS BOSCH 8 1
Divers
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION
DEPOLLUTION SUP
ATMOSPHÈRE
ATMOSPHERE NORMALE
CONDUITE A GAUCHE
PRISE D’ÉCOUTE RADIO
PRISE ACCESSOIRES
COTÉ CIRCULATION
CIRCULATION A DROITE
CHOCS LATÉRAUX
PORTE NON RENFORCEE
JEUX DE CLÉS
1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
EQUIPEMENT DE SECOURS
SANS EQUIPEMENT SECOURS
ROULAGE
BONNE ROUTE
BOÎTIER SERVITUDE
BSI + COM VOLANT MOYEU FIXE
TRIANGLE DE PRÉSIGNALISATION
SANS TRIANGLE PRESIGNALISATION
Rica
Moderator - Bazar
Mesajde Rica » Vin 14-Dec-2012 09:24
stiai tu atatea de masina ta? :twisted:
Ce ciudat!
mrk2012
Localitate: ROMANIA
problema
Mesajde mrk2012 » Vin 14-Dec-2012 23:47
e ca nu stiu nimik adik nu inteleg ce scrie acolo... poti sa imi explici mai pe indelete..dak ai timp macar cate-va mss
mesersmith
Moderator - C5
Localitate: calarasi
Masina: C5 III
2: C5 II
3: Peugeot 308
Mesajde mesersmith » Vin 14-Dec-2012 23:53
Presupun ca in romana iti e mai usor...
Caracteristicile vehiculului
Linie de produs C4
Nr. APV/PR 10952 88 1 0569
Data de Inceput de Garantie DDG 30.12.2006
OPB I00N
NRE e2*2001/116*0302*03
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C4
SILHOUETTE BERLINA CU 5 USI
FINITION SX VTR
MOTEUR INJECTIE TU5JP4
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KCW - VOPSEA SABLE DE LANGRUNE
TYPE D’HABILLAGE INTÉRIEUR VELUR COTTA + POINTIL "SQ"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA MA5 / N
MOTEUR (TYPE) MOTOR TIP TURBO/TURBODIESEL
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
FINITION SX VTR
Alimentare motor
ALIMENTATION INJECTIE "PRIM"
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI FONTA
CARBURANT BENZINA FARA PLUMB
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
CYLINDRÉE 1600 CM3
CATALYSEUR CATALIZATOR CU 3 COMPUSI IN FILTRE IMPREGNATE CU RODIU + PALADIU
REFROIDISSEMENT D’HUILE FARA SCHIMBATOR APA/ULEI
MOTEUR REFROIDISSEMENT RADIATOR EP:18 - 21 DM2 TP
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 2 TURATII 60W AERO
RÉCUPÉRATION DES VAPEURS D’ESSENCE DISPOZITIV PILOTAT DE RECUPERARE VAPORI DE BENZINA
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 13 X 61
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP MA/5 N
DIFFÉRENTIEL (BOITE) DIFERENTIAL 77
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 V CARE NU ESTE INTARIT
ROUES MONTÉES ROATA 6 INCI 1/2
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA NIVEL 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MA
Suspensie Directie Franare
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 27
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSION SUSPENSIE NORMALA
CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 1
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
PÉDALIER (TYPE) PEDALIER STANDARD
Caroserie Echipamente
AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
ANTENNE ANTENA SCURTA PAVILION
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTARE CU DEFLECTOR SPATE IN PARTEA SUPERIOARA A CAPACULUI DE PORTBAGAJ
DÉCORATION (PEINTE) DECORATIUNE COLORATA IN MASA
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
FEU D’ÉCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ETANCHÉITÉ AÉRODYNAMIQUE FARA GARNITURA DE CAPOTA MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORISATION COTÉ MOTEUR FARA IZOLARE FONICA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PARE-CHOCS BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
PARE-BOUE (BAVETTE) CU APARATORI DE ROTI SPATE
PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR + SUPORT + COMANDA SPATE NEUTRA RETROVIZOR IN CULOAREA CAROSERIEI
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (ASPECT) COLORATA
VITRE (TYPE) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ALLUME-CIGARE BRICHETA FATA
APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
APPUI-TÊTE AVANT TETIERA FATA REGLABILA
ASSISE ARRIÈRE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
GRADUATION VITESSES GRADATIE IN KM/H
COMPTE-TOURS TUROMETRU DIGITAL
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD MISTRAL FATADA INFERIOARA + SUPORT CREION NEUTRE
FEUX INT. DIVERS PLAFONIERA FATA 3 POZITII
COMBINÉ (CARACTÉRISTIQUES) TABLOU DE BORD DIGITAL CU FATADA GRI LION
GARNISSAGE DE PORTE PANOU DE USA FARA DECORATIUNE CROM SATINAT
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA PERDEA IMPOTRIVA SOARELUI
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RÉGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORTURI LOMBARE SI LATERALE CONDUCATOR
RÉGLAGE ASSISE AVANT PASSAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT COTIERA CENTRALA
COMPACT DISQUE FARA MONTARE COMPACT DISC
BOITE DE RANGEMENT FARA CONTAINER DE DEPOZITARE
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
MIROIR DE COURTOISIE OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA DE USA CU ASPECT NEUTRU
PLANCHER ARRIÈRE CHARGE FARA PLANSEU SPATE DE INCARCARE
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
PARE-SOLEIL AVANT PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DE DEPOZITARE LATERAL, INCHIS FARA SUPORT PENTRU OCHELARI
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
RANGEMENT VOLUME CHARGEMENT CU PLASA + COMPARTIMENT DE DEPOZITARE AMOVIBIL IN PORTBAGAJ
TAPIS MOCHETA TESUTA DILOUR F550
TUNER-RADIO CU UN SINGUR TUNER RADIO
PROTECTION INTÉRIEURE FARA PROTECTIE INTERIOARA
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE BURDUF + MANER STANDARD PLACUTA CROMATA
SURTAPIS FARA COVORAS SUPLIMENTAR
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN SPUMA CU 2 BRATE
RÉTROVISEUR INTÉRIEUR SURVEILLANCE ENFANT FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
Electricitate
ALTERNATEUR ALTERNATOR CLASA 8+
BATTERIE BATERIE L2 400
DÉMARREUR DEMAROR CLASA 3
ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION DEPOLUARE SUPERIOARA
ATMOSPHÈRE ATMOSFERA NORMALA
PRISE D’ÉCOUTE RADIO PRIZA ACCESORII
COTÉ CIRCULATION CIRCULARE PE DREAPTA
CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
BOÎTIER SERVITUDE BSI + COMANDA VOLAN BUTUC FIX
TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
Înapoi la “Tips/Tricks C4”
    Total mesaje 187775
    Total subiecte 18654
    Total membri 11822
    Cel mai nou membru pyms
