Pagina 1 din 1
PHONE IN CITROEN C4 AN 2007....
Scris: Mie 21-Noi-2012 21:18
de mrk2012
SALL AM SI IO NEVOIE NEAPARAT DE AJUTOR AM UN CITROEN C4 AN 2007 SI LA CASETOFONUL ORIGINAL DIN FABRICA LA SETARI PRIN EL IMI SCRIE PE DISPLAY ----PHONE IN---- NU INTELEG CE INSEAMNA LA CE SE REFERA...DAK ATI PUTEA SA MA AJUTATI AS FII FOARTE RECUNASCATOR...MULTUMESC...
Scris: Mie 21-Noi-2012 22:17
de joeadrianblack
cu mare placere... vezi ca ti-a ramas CapsLock-ul de la tastatura "pornit"...
Scris: Joi 22-Noi-2012 12:13
de Rica
si fara scurtaturi tip mess
Scris: Joi 22-Noi-2012 13:55
de MikePop
Pai ori are bluetooth ori are vreo mufa in spate ca sa legi vreun handsfree...
Scris: Joi 22-Noi-2012 13:56
de Rica
baga seria masinii si vedem ce dotari are
asa e cel mai simplu si sigur daca nu stii dotarile masinii
ok uite seria..
Scris: Joi 13-Dec-2012 17:29
de mrk2012
sper sa ma lamureestii....VF7LCNFUC74570568
mersii astept raspuns
Scris: Vin 14-Dec-2012 03:13
de MikePop
Informations gĂŠnĂŠrales
GENRE DE PRODUIT
VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE
CITROEN
LIGNE DE PRODUIT
C4
SILHOUETTE
BERLINE 5PTES
FINITION
SX VTR
MOTEUR
INJECTION TU5JP4
TRANSMISSION
BVM5
TYPE DE PEINTURE
PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE
KCW - PEINTURE SABLE DE LANGRUNE
TYPE DâHABILLAGE INTĂRIEUR
VELOURS COTTA + POINTIL "SQ"
COULEUR DE GARNISSAGE
"FZ"
BOITE DE VITESSES (CARACTĂRISTIQUES)
BVM MA5 / N
MOTEUR (TYPE)
MOTEUR TYPE TU/TUD
MONOGRAMME COMPLĂMENTAIRE, DIVERS
SANS MONOGRAMME COMPLEMENTAIRE
CaractĂŠristiques vĂŠhicule
FINITION
SX VTR
TYPE DE PEINTURE
COULEUR DE CAISSE
"FZ"
BVM MA5 / N
Alimentation moteur
MOTEUR
INJECTION TU5JP4
ALIMENTATION
INJECTION "PRIM"
DĂTECTEUR DâEAU FILTRE Ă GAZOLE
SANS DETECTEUR EAU FILTRE GASOIL
CARTER CYLINDRE (MATIĂRE)
CARTER CYLINDRE FONTE
CARBURANT
ESSENCE SANS PLOMB
DĂPOLLUTION (MOTEUR)
DEPOLLUTION EURO 4(MOTEUR)
MOTEUR (TYPE)
MOTEUR TYPE TU/TUD
CYLINDRĂE
1600 CM3
CATALYSEUR
CATALYSEUR 3 COMPOSES FILTRES IMPR RHODIUM+PALLADI
REFROIDISSEMENT DâHUILE
SANS ECHANGEUR EAU/HUILE
MOTEUR REFROIDISSEMENT
RADIATEUR EP:18 - 21 DM2 TP
RĂCHAUFFAGE CIRCUIT GAZ CARTER
SANS RECHAUFFAGE CIRCUIT GAZ CARTER
AUTODIAGNOSTIC EOBD
AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
DĂPOLLUTION TECHNIQUE VĂHICULE
DEPOLLUTION TECHNIQUE VEHICULE EURO 4
FILTRE Ă PARTICULE
SANS FILTRE A PARTICULES
VENTILATEUR
1 VENTILATEUR 2 VITESSES 60WAERO
RĂCUPĂRATION DES VAPEURS DâESSENCE
RECUP VAPEUR ESSENCE PILOTE
VARIANTE ASSOCIĂE INJECTION
SYSTEME INJECTION BOSCH
FILTRE RĂSERVOIR
FILTRE RESERVOIR INTERIEUR
BoĂŽte de vitesses Transmission
TRANSMISSION
BVM5
BVM MA5 / N
COUPLE RAPPORT
CP 13 X 61
STYLE ROUE
ROUE TOLE 16 POUCES
EMBRAYAGE
EMBRAYAGE HYDRAULIQUE
TYPE DE BOITE DE VITESSES (HOMOLOGATION)
TYPE BV MA/5 N
DIFFĂRENTIEL (BOITE)
DIFFERENTIEL 77
PNEUMATIQUE (DIMENSIONS, TYPE)
PNEU 205/55 R16 V NON RENFORCE
ROUES MONTĂES
ROUE 6 POUCES 1/2
ROUE (TYPE)
MONTAGE ROUE TOLE NIV 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE
SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE
BVM MA
Suspension Direction Freinage
BARRE ANTIDĂVERS ARRIĂRE
BARRE ANTI DEVERS AR DIAM 27
COLONNE DIRECTION
COLONNE DE DIRECTION REGLAGE MANUEL
ANTIDĂVERS AVANT
BARRE ANTI DEVERS AV DIAM 22
REFROIDISSEMENT DâHUILE POMPE DE DIRECTION
SANS REFROIDISSEMENT HUILE POMPE DIRECTION
SUSPENSION
SUSPENSION NORMALE
CONTRĂLE DYNAMIQUE DE STABILITĂ
SANS SYSTEME ESP
VARIANTE ASSOCIĂE FREIN
ABS BOSCH 8 1
DIRECTION (FONCTIONNEMENT)
DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
PĂDALIER (TYPE)
PEDALIER STANDARD
Carrosserie Equipements
AVERTISSEURS
AVERTISSEUR STANDARD
ANTENNE
ANTENNE PAVILLON COURTE
DĂFLECTEUR AĂRODYNAMIQUE ARRIĂRE
MONTAGE AVEC DEFLECTEUR AR SUPERIEUR VOLET
DĂCORATION (PEINTE)
DECOR TEINTE MASSE
ENJOLIVEMENT LATĂRAL (ASPECT)
PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEMENT LATĂRAL (DIMENSION)
SANS PROTECTEURS LATERAUX
ENJOLIVEUR ROUE (STYLE)
STYLE AZZANA 8 AJOURS 16 POUCES
FEU DE RECUL
AVEC 1 FEU RECUL
FEU DâĂCLAIRAGE DE SEUIL
SANS FEU ECLAIRAGE DE SEUIL
COMPLĂMENT DE PROTECTION (SOUS MOTEUR)
SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
ETANCHĂITĂ AĂRODYNAMIQUE
SANS JOINT CAPOT AV
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR
RETRO EXT RABATTABLE MANUEL
ENJOLIVEUR DE SORTIE DâĂCHAPPEMENT
SANS ENJOLIVEUR SORTIE ECHAPPEMENT
INSONORISATION COTĂ MOTEUR
SANS INSONORISATION
ESSUIE-VITRE AVANT
ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIĂRE
ESSUIE-VITRE AR
ESSUIE-PROJECTEUR
SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT
SANS OBTURATEUR FACE AV
VITRE PAVILLON
SANS VITRE PAVILLON
VITRE VOLET ARRIĂRE
VITRE VOLET AR FIXE
PARE-CHOCS
PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
PARE-BOUE (BAVETTE)
AVEC BAVETTES AR
PLAQUE POLICE
SANS PLAQUE POLICE
PORTE-BAGAGES
MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD
PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS
ROUE TOLE REDUITE+PNEU NON STD
ACCESSOIRES EXTĂRIEURS
POIGN EXT+PIED+CDE AR NEUTRE RETRO COUL CAISSE
RĂTROVISEUR EXTĂRIEUR (RAYON COTĂ CONDUCTEUR)
GLACE RETRO EXT BOMBE
TOIT OUVRANT
TOIT FIXE
ENJOLIVEMENT PARE-CHOCS
BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (ASPECT)
TEINTEE
VITRE (TYPE)
P-B FEUILL + LAT ET AR TREMPE
ACCĂS ET DĂMARRAGE MAINS LIBRES
SANS ACCES ET DEMARRAGE MAINS LIBRES
Equipement intĂŠrieur
ALARME ANTIVOL
SANS ALARME ANTIVOL
ALLUME-CIGARE
ALLUME CIGARE AVANT
APPUI-TĂTE ARRIĂRE
APPUI TETE AR REGLABLE
APPUI-TĂTE AVANT
APPUI-TETE AV REGLABLE
ASSISE ARRIĂRE
COUS SEPA RABATTBLE + DOSS SEPA RABATTABLE
ACCOUDOIR ASSISE ARRIĂRE
SANS ACCOUDOIR AR
CEINTURE DE SĂCURITĂ ARRIĂRE
CEINT SECU AR 3 ENROULEURS 3 PTS
CEINTURE DE SĂCURITĂ AVANT
CEINTURE PYROTECHNIQUE AVEC ALARME
CLIMAT (TEMPĂRATURE AMBIANTE)
PAYS FROIDS
CONDAMNATION ENFANT
CONDAMNATION ENFANT MANUELLE AR
GRADUATION VITESSES
GRADUATION EN KM/H
COMPTE-TOURS
COMPTE-TOURS NUMERIQUE
COTĂ DE CONDUITE (POSTE DE CONDUITE)
CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL
SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD
PL/BORD MISTRAL FACADE INF+PTE CRAYON NEUTRE
FUX INT. DIVERS
PLAFONNIER AV 3 POSITIONS
COMBINĂ (CARACTĂRISTIQUES)
COMBINE NUMERIQUE FACADE GRIS LION
GARNISSAGE DE PORTE
PANNEAU DE PORTE SANS DECOR CHROME SATIN
HAUT-PARLEUR
4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE DâAUTORADIO
CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT)
SANS RIDEAU PARE-SOLEIL
REHAUSSE ASSISE AVANT PASSAGER
SANS REHAUSSE ASSISE AV PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR
CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER
CDE SIEGE AV MANUEL PASSAGER
RĂGLAGE ASSISE AVANT CONDUCTEUR
SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
RĂGLAGE ASSISE AVANT PASSAGER
SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR
SANS RABATTEMENT ASSISE AV CONDUCTEUR
RABATTEMENT ASSISE AVANT PASSAGER
SANS RABATTEMENT ASSISE AV PASSAGER
ACCOUDOIR ASSISE AVANT
ACCOUDOIR CENTRAL
COMPACT DISQUE
SANS MONTAGE COMPACT DISQUE
BOITE DE RANGEMENT
SANS BOITE DE RANGEMENT
SYSTĂME DE NAVIGATION
SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS
LAMPE HALOGENE
LĂVE-VITRE ARRIĂRE
LEVE-VITRE AR CDE MANUELLE
LECTEUR DâINFORMATIONS ROUTIĂRES
SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR
AFFICHEUR (RADIO+MONTRE+ET OU T°,CD) SANS MEMOIRE
MIROIR DE COURTOISIE
CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
INDICATEUR DâHUILE
RECEPTEUR NIVEAU HUILE
MONTAGE APPUI-TĂTE ARRIĂRE
MONTAGE 3 APPUI-TETE AR
NAPPE CHAUFFANTE
SIEGE NON CHAUFFANT
SAC GONFLABLE LATĂRAL AVANT
SAC GONFLABLE LATERAL THORAX + RIDEAU
SAC GONFLABLE PASSAGER
SAC GONFLABLE COTE PASSAGER
LĂVE-VITRE ĂLECTRIQUE (FONCTIONNEMENT)
ANTI PINCEMENT CONDUCTEUR + PASSAGER
PACK ĂQUIPEMENT
SANS PACK EQUIPEMENT AUTO-ECOLE
RETRO EXT CHAUFFANT
NEUTRALISATION COUSSIN GONFLABLE
NEUTRALISATION MANUELLE COUSSIN GONFLABLE
COMMANDE INTĂRIEURE DE PORTE (ASPECT)
COMMANDE INTERIEURE PORTE ASPECT NEUTRE
PLANCHER ARRIĂRE CHARGE
SANS PLANCHER AR CHARGE
PROJECTEUR CORRECTEUR ASSIETTE
REGLAGE MANUEL A DISTANCE PROJECTEURS
PROTECTION POSTE AVANT
SANS PROTECTION POSTE AV
PARE-SOLEIL AVANT
COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
RANGEMENT (POSTE CONDUITE)
RANGEMENT LAT FERME SANS LUNETTE
RĂCEPTEUR RADIO
SYSTEME AUDIO COMPACT DISC RDS "RD4"
RĂFRIGĂRATION
REFRIGERATION AUTOMATIQUE
RĂGULATEUR DE VITESSES
REGULATEUR ET LIMITEUR VITESSE
REHAUSSE ASSISE AVANT CONDUCTEUR
REHAUSSE CONDUCTEUR REGLAGE PARALLELE
RĂTROVISEUR INTĂRIEUR
RETROVISEUR INT JOUR - NUIT NON ELECTROCHROME
SURTAPIS (ASPECT)
SANS SURTAPIS
SAC GONFLABLE CONDUCTEUR
SAC GONFLABLE COTE CONDUCTEUR
RANGEMENT VOLUME CHARGEMENT
AVEC FILET + RANGEMENT AMOVIBLE DANS COFFRE
TAPIS
MOQUETTE AIGUILLETEE DILOUR F550
TUNER-RADIO
MONO TUNER RADIO
PROTECTION INTĂRIEURE
SANS PROTECTION INTERIEURE
DĂTECTION DâOBSTACLE
SANS DETECTEUR OBSTACLE
STORES LATĂRAUX
SANS STORES LATERAUX
ADAPTATION GARNITURE
SOUFFLET + POMMEAU STD PASTILLE CHROME
SURTAPIS
SANS SURTAPIS
AMPLI-ĂQUALISEUR
SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE
VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VITRE (TYPE)
VOLANT
VOLANT MOUSSE 2 BRAS
VENTILATEUR
RĂTROVISEUR INTĂRIEUR SURVEILLANCE ENFANT
SANS RETROVISEUR INTERIEUR SURVEILLANCE ENFANT
ElectricitĂŠ
ALTERNATEUR
ALTERNATEUR CLASSE 8+
AVERTISSEURS
BATTERIE
BATTERIE L2 400
DĂMARREUR
DEMARREUR CLASSE 3
ECLAIREMENT PARTICULIER
SANS ECLAIRAGE PARTICULIER
FEU DE RECUL
AVEC 1 FEU RECUL
FEUX INT. DIVERS
LAMPE HALOGENE
MULTIPLEXAGE
MONTAGE MULTIPLEXE CAN CAN
Marques d'ĂŠquipements
ABS BOSCH 8 1
Divers
CRITĂRE VARIANCE, CLIENTĂLE CONCEPTION
DEPOLLUTION SUP
ATMOSPHĂRE
ATMOSPHERE NORMALE
CONDUITE A GAUCHE
PRISE DâĂCOUTE RADIO
PRISE ACCESSOIRES
COTĂ CIRCULATION
CIRCULATION A DROITE
CHOCS LATĂRAUX
PORTE NON RENFORCEE
JEUX DE CLĂS
1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
EQUIPEMENT DE SECOURS
SANS EQUIPEMENT SECOURS
ROULAGE
BONNE ROUTE
BOĂTIER SERVITUDE
BSI + COM VOLANT MOYEU FIXE
TRIANGLE DE PRĂSIGNALISATION
SANS TRIANGLE PRESIGNALISATION
Scris: Vin 14-Dec-2012 09:24
de Rica
stiai tu atatea de masina ta?
problema
Scris: Vin 14-Dec-2012 23:47
de mrk2012
e ca nu stiu nimik adik nu inteleg ce scrie acolo... poti sa imi explici mai pe indelete..dak ai timp macar cate-va mss
Scris: Vin 14-Dec-2012 23:53
de mesersmith
Presupun ca in romana iti e mai usor...
Caracteristicile vehiculului
Linie de produs C4
Nr. APV/PR 10952 88 1 0569
Data de Inceput de Garantie DDG 30.12.2006
OPB I00N
NRE e2*2001/116*0302*03
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C4
SILHOUETTE BERLINA CU 5 USI
FINITION SX VTR
MOTEUR INJECTIE TU5JP4
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KCW - VOPSEA SABLE DE LANGRUNE
TYPE D’HABILLAGE INTĂRIEUR VELUR COTTA + POINTIL "SQ"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTĂRISTIQUES) CUTIE DE VITEZE MANUALA MA5 / N
MOTEUR (TYPE) MOTOR TIP TURBO/TURBODIESEL
MONOGRAMME COMPLĂMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
FINITION SX VTR
Alimentare motor
ALIMENTATION INJECTIE "PRIM"
DĂTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI FONTA
CARBURANT BENZINA FARA PLUMB
DĂPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
CYLINDRĂE 1600 CM3
CATALYSEUR CATALIZATOR CU 3 COMPUSI IN FILTRE IMPREGNATE CU RODIU + PALADIU
REFROIDISSEMENT D’HUILE FARA SCHIMBATOR APA/ULEI
MOTEUR REFROIDISSEMENT RADIATOR EP:18 - 21 DM2 TP
RĂCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 2 TURATII 60W AERO
RĂCUPĂRATION DES VAPEURS D’ESSENCE DISPOZITIV PILOTAT DE RECUPERARE VAPORI DE BENZINA
VARIANTE ASSOCIĂE INJECTION SISTEM DE INJECTIE BOSCH
FILTRE RĂSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 13 X 61
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP MA/5 N
DIFFĂRENTIEL (BOITE) DIFERENTIAL 77
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 V CARE NU ESTE INTARIT
ROUES MONTĂES ROATA 6 INCI 1/2
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA NIVEL 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MA
Suspensie Directie Franare
BARRE ANTIDĂVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 27
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDĂVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSION SUSPENSIE NORMALA
CONTRĂLE DYNAMIQUE DE STABILITĂ FARA SISTEM ESP
VARIANTE ASSOCIĂE FREIN ABS BOSCH 8 1
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
PĂDALIER (TYPE) PEDALIER STANDARD
Caroserie Echipamente
AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
ANTENNE ANTENA SCURTA PAVILION
DĂFLECTEUR AĂRODYNAMIQUE ARRIÈRE MONTARE CU DEFLECTOR SPATE IN PARTEA SUPERIOARA A CAPACULUI DE PORTBAGAJ
DĂCORATION (PEINTE) DECORATIUNE COLORATA IN MASA
ENJOLIVEMENT LATĂRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATĂRAL (DIMENSION) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
FEU D’ĂCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ETANCHĂITĂ AĂRODYNAMIQUE FARA GARNITURA DE CAPOTA MOTOR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ENJOLIVEUR DE SORTIE D’ĂCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORISATION COTĂ MOTEUR FARA IZOLARE FONICA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PARE-CHOCS BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
PARE-BOUE (BAVETTE) CU APARATORI DE ROTI SPATE
PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
ACCESSOIRES EXTĂRIEURS MANER EXTERIOR + SUPORT + COMANDA SPATE NEUTRA RETROVIZOR IN CULOAREA CAROSERIEI
RĂTROVISEUR EXTĂRIEUR (RAYON COTĂ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (ASPECT) COLORATA
VITRE (TYPE) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCÈS ET DĂMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ALLUME-CIGARE BRICHETA FATA
APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
APPUI-TÊTE AVANT TETIERA FATA REGLABILA
ASSISE ARRIÈRE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CEINTURE DE SĂCURITĂ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CEINTURE DE SĂCURITĂ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMAT (TEMPĂRATURE AMBIANTE) TARI CU CLIMA RECE
CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
GRADUATION VITESSES GRADATIE IN KM/H
COMPTE-TOURS TUROMETRU DIGITAL
COTĂ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD MISTRAL FATADA INFERIOARA + SUPORT CREION NEUTRE
FEUX INT. DIVERS PLAFONIERA FATA 3 POZITII
COMBINĂ (CARACTĂRISTIQUES) TABLOU DE BORD DIGITAL CU FATADA GRI LION
GARNISSAGE DE PORTE PANOU DE USA FARA DECORATIUNE CROM SATINAT
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) FARA PERDEA IMPOTRIVA SOARELUI
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RĂGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORTURI LOMBARE SI LATERALE CONDUCATOR
RĂGLAGE ASSISE AVANT PASSAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT COTIERA CENTRALA
COMPACT DISQUE FARA MONTARE COMPACT DISC
BOITE DE RANGEMENT FARA CONTAINER DE DEPOZITARE
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
MIROIR DE COURTOISIE OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATĂRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
LÈVE-VITRE ĂLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
PACK ĂQUIPEMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
COMMANDE INTĂRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA DE USA CU ASPECT NEUTRU
PLANCHER ARRIÈRE CHARGE FARA PLANSEU SPATE DE INCARCARE
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
PARE-SOLEIL AVANT PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DE DEPOZITARE LATERAL, INCHIS FARA SUPORT PENTRU OCHELARI
RĂCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RĂFRIGĂRATION SISTEM DE REFRIGERARE AUTOMATA
RĂGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RĂTROVISEUR INTĂRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
RANGEMENT VOLUME CHARGEMENT CU PLASA + COMPARTIMENT DE DEPOZITARE AMOVIBIL IN PORTBAGAJ
TAPIS MOCHETA TESUTA DILOUR F550
TUNER-RADIO CU UN SINGUR TUNER RADIO
PROTECTION INTĂRIEURE FARA PROTECTIE INTERIOARA
DĂTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
STORES LATĂRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE BURDUF + MANER STANDARD PLACUTA CROMATA
SURTAPIS FARA COVORAS SUPLIMENTAR
AMPLI-ĂQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN SPUMA CU 2 BRATE
RĂTROVISEUR INTĂRIEUR SURVEILLANCE ENFANT FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
Electricitate
ALTERNATEUR ALTERNATOR CLASA 8+
BATTERIE BATERIE L2 400
DĂMARREUR DEMAROR CLASA 3
ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION DEPOLUARE SUPERIOARA
ATMOSPHÈRE ATMOSFERA NORMALA
PRISE D’ĂCOUTE RADIO PRIZA ACCESORII
COTĂ CIRCULATION CIRCULARE PE DREAPTA
CHOCS LATĂRAUX USA CARE NU ESTE INTARITA
JEUX DE CLĂS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
BOĂTIER SERVITUDE BSI + COMANDA VOLAN BUTUC FIX
TRIANGLE DE PRĂSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
