U4GM Why Pinpoint Pitching Is Best in MLB The Show 26
Forum de discutii generale despre Citroen AX. Numai ce nu se incadreaza in categoriile de mai jos.
Andrew736
Localitate: New York
Mesajde Andrew736 » Lun 16-Mar-2026 05:20
Pitching in MLB The Show 26 still feels like the difference between cruising through a ranked game and watching a three-run bomb ruin your night, so it's worth getting set before you even throw pitch one. If you're tinkering with your squad or opening MLB stubs, take five minutes to dial in a pitching interface you can actually repeat under pressure, because your input matters more than your plan when your hands get shaky in the 8th.
Pick an interface you can trust
1) Pinpoint is still king for control, no question. When you're locked in, you can dot corners and steal strikes that shouldn't be strikes. But if you're even a little late, it'll punish you. 2) Pulse is the "my controller's acting up" option, and honestly it's not bad at all. Tap as the circle tightens and you'll survive messy innings without feeling like the game's fighting you. 3) Meter is familiar and it works, but with low-rated arms the timing window feels tiny, and you'll hang stuff if you rush it. 4) Pure Analog is fun if you like the stick motion, though it can get wild when you're trying to paint inside. 5) Classic is the chill mode: aim, hit the button, and let ratings do the lifting, which is great if you're tired of over-correcting every pitch.
Stop pitching on autopilot
The real killer isn't "wrong pitch selection," it's patterns. A lot of players don't even notice they're doing it. You throw two high four-seamers early, then you're back up there again because it felt safe. Next thing you know, it's 2-0 and the hitter's sitting on it. Try working in layers instead. Start with something that looks hittable, then yank it away. Go sinker in off the plate, then slider that starts middle and falls under the barrel. Changeups play better when you've shown a fastball for a strike recently. And don't be scared to waste a pitch on purpose. A curve in the dirt can set up a cutter on the hands way better than another "perfect" strike.
Stamina, bullpen, and the new Bear Down swings
Once your starter gets up around that 75–85 pitch range, you'll feel it: input gets sloppy, misses get bigger, and the contact sounds louder. If the energy bar's dipping and you're still trying to squeeze one more inning, you're basically daring the game to punish you. Get your pen moving early, even if it's just a soft warm-up, so you're not forced into a cold reliever. And Bear Down is the new ace up your sleeve. It's tied to Clutch, and it's best treated like a fire extinguisher, not a toy. Save it for bases loaded, two outs, or when you absolutely need a strikeout and you can't afford a hanger.
Keep the run going without chasing every upgrade
Pitching well in 26 is mostly about staying calm and staying unpredictable. You'll have innings where your thumb feels off, or the opponent won't chase anything, and that's fine. Make the simple move: change the eye level, change the speed, and don't marry any one pitch. If you're building out your roster alongside that grind, a lot of players use U4GM because it's a professional, convenient platform for getting game currency and items without the extra hassle, and you can buy MLB The Show 26 stubs in u4gm when you want a smoother team-building experience without derailing your time on the mound.
Înapoi la “Citroen AX”
    Total mesaje 187965
    Total subiecte 18712
    Total membri 11844
    Cel mai nou membru Andrew736
