incinge dupa ce am schimbat garnitura de chiuloasa
truck_mihai
- Localitate: GRANADA SPANIA
Emil Paunas
- Localitate: TARGOVISTE, DB
truck_mihai
truck_mihai
truck_mihai
FRRRRRATILORRRRRRR MASINA MEA [b] TRAIESTE
AM UMBLAT ASTAZI VREO 180 KM CA SA CAUT POMPA DE INJECTIE
PE LA TOATE DEZMEMBRARILE PE CARE LE CUNOSC
IN ACEASTA ZONA,AM GASIT IN SFARSIT
O POMPA DE INJECTIE IDENTICA CU A MEA
DAR CU IMOBILIZATOR SI MI-AU
ZIS DE ACOLO CA SE POATE MONTA
SI DACA VR SA-I DAU JOS IMOBILIZATORUL
SAU NU!! SI CA DACA NU MERGE
SA MA DUC CU EA INAPOI SI MI-O SCHIMBA IN SFARSIT
AM PUS-O PE MASINA DUPA CE AM DAT IMOBILIZATORUL JOS
AM AMORSAT INSTALATIA DE ALIMENTARE SI AM MASINA!!!!!!
A PORNIT IMEDIAT AM PLECAT IN PROBE CU EA.
APA DUPA CUM STITI FARA TERMOSTAT STATEA LA 90-100 GRADE c.
ACUMA DEABIA A AJUNS LA 80 GRADE c IN SCHIMB MERGE ROTUND
TRAGE SI FUGE CA SI INAINTE
MAINE MA DUC SA IAU SONDA DE LA VENTILATOR O SCHIMB SI PE AIA
II PUN SI TERMOSTATUL LA LOC
SI DUPAAIA SA VEDEM CUM FUNCTIONEAZA!!!!!!
SA-R PUTEA SA FI FOST DIN CAUZA POMPEI DE INJECTIE
CA I-MI INCALZEA CU TOATE CA SCHIMBASEM GARNITURA DE CHIULOASA
DAR DEOCAMDATA NU SUNT SIGUR PANA MAINE
URATI-MI NOROC
SANATATE SI DRUMURI BUNE TUTUROR!!!!
URATI-MI NOROC
benny_merty
- Localitate: Sibiu Cisnadie
benny_merty
Emil Paunas
truck_mihai
IN PRIMUL RAND TIN SA VA MULTUMESC TUTUROR INCA ODATA PENTRU CA MIA-TI SOST ALATURI
SI MA-TI INDRUMAT SI AJUTAT FIECARE CUM A-TI PUTUT
ACUMA VIN CU NISTE RECTIFICARI
am demontat pompa de pe masina dupa ce nu mai mergea cum trebuia nu ca nu aveam ce face
deci pentru ca masina nu mergea rotund , dadea sa se opreasca , curgea motorina de cam peste tot ,
dar in primul rand pentru ca dadea cu motorina printre corpul de aluminiu al pompei si corpul negru (capul hidraulic )
al acesteia si pentru ca oricum ma gandeam sa-mi cumpar alta
in acest fel m-am gandit ca nu am ce sa stric mai rau la ea (pompa) dechit era deja si da nestind ce am sa gasesc acolo
inauntru nu am tinut cont de distanta aia de care vorbeste EMIL PAUNAS aici
fapt pentru care cand am desfacut-o - eu nestiind ce are inauntru si mai ales cum sa o desfac -
m-am trezit in palma cu rolele si toate celelalte 6 pastile ce intra in componenta capului hidraulic
BINENTELES CA DUPA CE AM MONTAT-O DIN NOU PE MASINA nu a mai functionat nici macar asa rau cum functiona
inainte de a o da jos dar tot raul spre bine.
ACUMA SANT ASA DE BUCUROS CA NICI NU VA INCHIPUITI!!!!!!!!!!!!!!!!!!!!!!!!!
REFERITOR la repararea celei care am dat-o jos am intrebat la un atelier ce repara pompe si injectoare
si mi-a spus ca ar costa in jur de 300 de euro - probabil va amintiti ca locuiesc in SPANIA in GRANADA -
iar la dezmembrari am gasit-o cu 60 de euro
in acest fel am zis ca nu dau eu 300 de euro nici sa moara ei
DAR oricum este o idee buna ca nu stii cat te poate tine asta dar deocamdata este bine si asa mai ales ca acuma nu am de munca
poate daca i-mi gasesc ceva de munca am sa o duc la reparat si nu de altceva dechit pentru faptul ca abia am gasit-o dupa multe sapaturi
v-am spus ca am alergat sa o caut vreo 180 de km- prin vreo 33 de dezmembrari -oricum toate bune si frumoase DEOCAMDATA sa ma duc acum sa cumpar si sonda si rezervorul si sa vad daca mai incinge dupa aia .
ACUMA PLEC SA CUMPAR SONDA SI REZERVORUL DE APA
va anunt
multumiri tuturor (desi stiu ca aveti podul casei plin de multumiri) si drumuri bune!!!!!!!!!!!!!!!!!!!!
va anunt
truck_mihai
iar distributia a fost reglata corect pentru ca de fiecare data cand am dat-o jos am blocat roata dintata
a pompei de injectie cu cele doua suruburi care ajuta la punerea ei la punct
deci roata dintata ramanand pe motor cu cureaua de distributie pusa
cu alte cuvinte nu am desfacut cureaua de pe motor a fost o idee
de a mea
nu stiam daca o sa mearga sa dau pompa jos in felul asta!!!!!!!!!!!!
am plecat !!!!!!!!!!
truck_mihai
am zis ... dar nu
s-a ars iar garnitura de chiuloasa cuuuuuum nici eu nu stiu am mai mers cu ea m-am dus sa fac niste mici la padure
toate bune nu s-a ridicat apa mai mult de 90 de grade dar cand sa plec nu a mai vrut sa porneasca de loc, am adus-o
acasa pe platforma iar nervos necajit ce am fost si sant inca pentru ca am vrut sa fac cat mai putine celtuieli cu ea
deja bagasem o caruta de bani in ea
Adevarul adevarat este ca nu s-a prajit ci ca s-a rupt garnitura prin spatele motorului in dreptul pistonului numarul unu
poate ca nu-mi dadeam seama dar cand am adus-o acasa mi-a zis soferul ca i-am murdarit platforma de ulei
A doua zi am gasit o mare balta de ulei sub ea ( mare nu chiar doar pete ici si colo majoritatea pe partea stanga cum
te uiti la ea din fata) asa ca am inceput de aici sa privesc pe toate partile pe unde se putea vedea ceva , nu prea mi-
am dat seama ce ar putea sa aiba si de unde sa vina uleiul ala asa ca am zis sa o pornesc sa vad pe unde il dadea .
Binenteles ca nu am reusit sa pornesc am consumat toata bateria si degeaba nimic . In tot timpul asta vezi vine
motorina ,desfa colo desfa dincolo strange pe ici pe colo nimic , zic e clar : E STRICATA !!!!!!!! In acel moment ,
am zis sa incerc sa-i dau la automat direct de la electromotor , iau o cheie fac contact si incepe sa invarta si aud
bolborosind in vasul de expansiune . AM CREZUT CA NU AUD EU BINE dau capacul jos de la rezervorul de apa si
fac din nou contact pe direct la electromotor .
Cat dadeam la automat incepea sa bolboroseasca in vas si chiar sa se ridice apa in sus aproape sa dea apa pe afara
M-am trezit de dimineata fara nici un chef de munca si dupa ce ca nu aveam chef cand am vazut chestia asta m-ia
trecut si cel pe care il aveam .Maine poate iau vreo pastila de chef de munca si poate continui din nou cu desfacutul
chiuloasei de data asta schimb si chiuloasa!
eu sant in spania in granada mai exact daca ma poate ajuta cineva cu un sfat sau cu o chiuloasa las aici adresa mea
de mail:
truck_mihai@yahoo.com
DRUMURI BUNE TUTUROR SI SANATATE!!!!!!!!!!!
de mail:
truck_mihai
truck_mihai
o intrebare poate ma ajuta cineva
stie cineva daca pun o chiuloasa din anul 2000 de la un motor fara turbo in loc de una din anul 1997 la un motor turbo de 75 cp
ce se poate intampla si cam cat poate sa dureze
treaba este ca mi s-a rupt garnitura de chiuloasa a doua oara in timp de 2 luni din cauza chiuloasei ca era fisurata
singura diferenta care am remarcat-o la aceasta chiuloasa din 2000 fata de ce am avut eu pe masina (1997) este ca injectoarele
sant cu pasul filetului mai marunt la asta din 2000 si ca preincalzitoarele sant dispuse deasupra injectoarelor si ele
(preincalzitoarele) sant mai subtiri si mai lungi in rest nu sant alte diferente
intrebarea mea este daca se potriveste inseamna ca as putea sa o pun , nu????????????????
si cat ar putea sa dureze in timp sau daca ar fi vreo problema din aceasta cauza (pentru ca nu este chiuloasa de turbo)
iar al meu motor este turbo dar este ala mic de 75 de cai nu este cel de 90 de cai ???????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
truck_mihai
Total membri 11832
Cel mai nou membru CezarXsara
