Corespondenta turatie-viteza
- dindamaroaia
- Localitate: Sebastian
http://www.ciao.co.uk/Citroen_C1__Review_5605849
The engine of C1 gives maximum torque, or pulling ability, at around 3600 r.p.m:
- In 5th gear this corresponds to 75mph adica 121 km
- In 4th gear this corresponds to 60mph adica 97 km
- In 3rd gear this corresponds to 50mph adica80 km
- In 2nd gear this corresponds to 30mph adica 48 km
- In 1st gear this corresponds to 15mph adica 24 km
Cuplul maxim este 93 Nm la 3600 rpm ( motor pe benzina )
By madlex456_sb at 2007-08-28
Am mai gasit ceva despre turatii si viteza
At 1000 rpm the speed is:
• 1st gear - 8,1 km/h
• 2nd gear - 15,1 km/h
• 3th gear - 21,91 km/h
• 4th gear - 27,96 km/h
• 5th gear - 33,78 km/ h
At 3600 rpm (max torque) the speed is:
• 1st gear - 29,16 km/h
• 2nd gear - 54,36 km/h
• 3th gear - 78,876 km/h
• 4th gear - 100,656 km/h
• 5th gear - 121,608 km/h
Switching gear (up) at max torque:
• 1st gear - 6700rpm = 2nd gear - 3600rpm
• 2nd gear - 5200rpm = 3th gear - 3600rpm
• 3th gear - 4600rpm = 4th gear - 3600rpm
• 4th gear - 4350rpm = 5th gear - 3600rpm
Switching gear (down) at max torque:
• 2th gear - 2000rpm = 1st gear - 3600rpm
• 3th gear - 2500rpm = 2nd gear - 3600rpm
• 4th gear - 2800rpm = 3th gear - 3600rpm
• 5th gear - 3000rpm = 4th gear - 3600rpm
Salutare! Tin sa va anunt ca am incercat astazi sa conduc cum spune-ti voi... sa schimb la peste 3000 ture... sau cum scrie mai sus! Mi-a fost imposibil!!!!! In a 2 a aveam 60, nici nu plecam bine de pe loc ca trebuia sa franez, ba la stop, ba un tigan traversa pe unde nu trebuia, ba aglomeratie... etc! Pur si simplu am folost numai primele doua viteze, daca ii dadeam a 3 -a cred ca ma lasau astia fara permis vreo 3 luni de zile pt viteza! Nu stiu ce concluzie sa trag din asta... dar sigur in oras nu poti sa schimbii la 3000! Stiti cum e... una e in carti, alta in realitate!
sincer eu nu schimbam sub 3000 nici la dacia pe carburatie, la toate daciile pe carburatie pe care le-am avut! chiar nu glumesc, nu am avut niciodata probleme, bineinteles eu puneam castrol, aral, in cel mai rau caz elf, in timp ce altii foloseau numai "ULEI DE MOTOR" la 50.000 bidonul si imi dadeau mie lectii ca daca schimb la 3000 distrug motorul...ei bine, nu l-am distrus la nici una din ele. deci fii sigur ca la c1 3600-4000 RPM e normal.
daca ti se pare ca rulezi prea repede, pur si simplu ramai intr-o treapta inferioara. daca la dacia cu a 1-a plecam de pe loc, cu c1 accelerez , daca foloseam a 2-a sa accelerez, cu c1 merg constant, daca cu a 3-a mergeam constant cu c1 merg chiar repede, si daca cu dacia in a 4-a mergeam mai repede, cu c1 zbor....
deci e cu o treapta peste dacie ca performanta generala.
nu stiu daca am fost prea clar, dar sper ca ai prins ideea.
Total mesaje 187809
Total subiecte 18664
Total membri 11834
Cel mai nou membru Mihneazp
