poate sa imi spuna si mie cineva info despre o masina
vin :vf7n1rhyb73808230
multumesc frumos
vin xsara
iote...
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XSARA II
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL MEDIUM MEDIUM
ENGINE TURBO DIESEL DW10TD
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EYT - PAINT STORM GREY
INTERIOR TRIM TYPE "MM" CESIUM VELOUR
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EW/DW
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " XSARA
BADGE XSARA + HDI
SPEEDOMETER DRIVE TACHO TORQUE 22X19
DIESEL FILTER WATER DETECTOR WITH DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
ENGINE (TYPE) EW/DW
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
COOLING MOTOR RADIATOR THICKNESS: 27 -21 3 DM2 MBA HP
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF DIAGNOSTICS WITHOUT SOFT
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
FAN 1 FAN 3 SPEEDS 420W
INJECTION ASSOCIATED VARIANT SIEMENS ASSEMBLY
HYBRID DRIVE TRAIN WITHOUT ALTERNATOR-STARTER
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
HORNS HORN STANDARD
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) 15 INCH BACCARAT 2 STYLE - 8 OPENINGS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK LARGE AIR ENTRANCE FRONT BUMPER PLUG
OUTSIDE TEMPERATURE SENSOR WITH EXTERIOR TEMPERATURE SENSOR
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) IMPERVIOUS TO RADIANT HEAT
WINDOW (TYPE) ATHERMAL WINDSCREEN
EXTERIOR STYLING PACK BODY COLOUR EXTERIOR LOOK PACK
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITHOUT REAR ARMREST
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT AXIS GREY DECOR
MISC. INT. LAMPS MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS) 220 KM/H OR 140 MPH GRADUATION GREY/BLUE DIAL
LOUDSPEAKER MOUNTING 4 FRONT LOUDSPEAKERS + 2 REAR
RADIO CONTROLS REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
DRIVER SEAT ADJUSTMENT WITHOUT DRIVER’S LUMBER AND SIDE SUPPORTS
FRONT PASSENGER SEAT ADJUSTMENT WITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
CD-ROM FOR CAR PC WITHOUT CD ROM FOR AUTO-PC
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT NON SEQUENTIAL FRONT PASSENGER’S ELECTRIC WINDOW
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVER’S ANTI-PINCH + REAR MANUAL
ON-BOARD COMPUTER COMPUTER
EQUIPMENT PACK WITHOUT DRIVING SCHOOL EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
STORAGE (DRIVING POSITION) INJECTED LOWER GLOVE BOX
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION REGULAR AIR CONDITIONNING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
WEAR INDICATOR W/O BRAKE WEAR WARNING LIGHT
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
TRIM ADAPTATION GEAR LEVER KNOB WITH PAINTED INSERT
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L2 400
STARTER MOTOR CLASS 6 STARTER MOTOR
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
PRODUCT TYPE CAR
TRANSMISSION BVM5
ENGINE (TYPE) EW/DW
BADGE XSARA + HDI
FUEL DIESEL FUEL
ENGINE (TYPE) EW/DW
HORNS HORN STANDARD
SUN ROOF FIXED ROOF
HORNS HORN STANDARD
Total membri 11830
Cel mai nou membru Dady
