Pret?!
Pret?!
Cam ce pret ar avea un C5-2 2005, Motor 1.6 HDI,110 CP,full option(navigatie,faruri adaptive cu xenon,AFIL,asistenta parcare,senzori ploaie etc) adusa recent din Germania,~190.000Km putin zgariata in partea din spate?
- Localitate: Cluj-Napoca
Nu e full option. Nu e nici macar Exclusive. E un nivel mare de dotari, totusi. Ca idee, nu are: servo directie variabila, nu are alarma, nu are cotiera spate, nu are incalzire auxiliara, nu are perdeluta spate, nu are sistem audio JBL, nu are scaun reglabil pe inaltime la pasager, nu are cotiera fata, nu are incalzirea in scaune.
E o masina dotata bine, dar de la asta la a zice "Full Option" mai este cale lunga.
Dupa parerea mea, nu ar trebui sa iei C5 cu motorul de 1.6 HDI. Dupa parerea mea, masina aia are mai mult de 190 000 km. De ce? Pentru ca, in primul rand, zici ca e "recent adusa din Germania", deci samsar, in al doilea rand, e 1.6 hdi care e super folosit pentru firme, si in ultimul rand e 190 000km ceea ce pare suspect din start.
Vehicle characteristics
Vehicle family C5 II
AS RPO No 10340 CJ 1 0099
Warranty Start Date 16/03/2005
OPB A047
BER e2*2001/116*0305*02
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 II
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL MEDIUM HIGH
ENGINE DIESEL TURBO DV6TED4 FAP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EYL - PAINT - ICELAND GREY
INTERIOR TRIM TYPE SHOW "SM" CLOTH
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EV/DV
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE C5
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE CT 22 X NO
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
ENGINE (TYPE) EV/DV
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
COOLING MOTOR RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD POWER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 150W
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
TANK FILTER RESERVOIR FILTER INTERIOR
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE 16 INCH HUNGARO WHEEL
CLUTCH HYDRAULIC CLUTCH
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 215X55X16 W TYRES
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR TYRE DEFLECTION INDICATOR
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED MANUAL STEERING
Body fittings
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION) PLASTIC SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) HUNGARO TYPE
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXT REAR VIEW MIRROR NO MEMORY
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER HEADLAMP WASHWIPE
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
REAR TAILGATE GLASS FIXED TAILGATE WINDOW
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
WINDOW (TYPE) HEAT W/SCRN+ACCOUS+REFL+LAM SIDE+RR TOUGHENED
EXTERIOR STYLING PACK BODY COLOUR EXTERIOR LOOK PACK
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITH REAR ARMREST
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT CUBIC MINIWEAVE DECOR
LOAD SPACE TRIM W/O MAT
UNDERSEAT STORAGE 1 UNDER SEAT STORAGE DRAWER
DOOR TRIM CUBIC MINIWEAVE DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
INT. UPHOLSTERY ELEMENTS CLOTH B/C POST TRIM + POLYPRO QUARTER PANEL
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC MOUNTING COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS DISCHARGE BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITH LATERAL TRAJECTORY MONITORING
DISPLAY DISPLAY (NAVIGATION+VIDEO+RADIO+CLOCK, TEMP, CD)
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGE TEMPERATURE RECEIVER
HEATING ELEMENT NON HEATED SEAT
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
RADIO RECEIVER "RT3" RADIOTELEPHONE SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR OR SPEED LIMIT
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
AMBIENCE PACK WITHOUT AMBIANCE PACK
RADIO-INFORMATION-COMMUNICATION PACK RT3 + COLOUR NAV
SEAT LUMBAR SUPPORT (OPERATION) MANUAL LUMBAR SUPPORT
Electrical
ALTERNATOR ALTERNATOR 150 AMP
STARTER MOTOR CLASS 6 STARTER MOTOR
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE CONDITIONNING
OPB A047
General information
PRODUCT TYPE CAR
TRANSMISSION BVM5
ENGINE (TYPE) EV/DV
BADGE C5
Fuel supply-Engine
FUEL DIESEL FUEL
ENGINE (TYPE) EV/DV
Gearbox-Driveshafts
TRANSMISSION BVM5
Body fittings
SUN ROOF FIXED ROOF
Interior fittings
Electrical
Miscellaneous
Ultima oară modificat Lun 24-Sep-2012 15:01 de către mbc, modificat 1 dată în total.
Asta nu stiu,se comporta ok deocamdata
Masina e cumparata pentru mine.am fost personal in germania acum ~5 luni cu un prieten care se ocupa cu masini d-astea.Iar masina am luat-o de la o persoana de 50 si ceva de ani parca, din curte.
Ultima oară modificat Lun 24-Sep-2012 15:05 de către ady9110, modificat 1 dată în total.
Mie nu mi se pare putin 190.000 de km la o masina din 2005.
Adica e o cifra rezonabila. Si in niciun caz cuantificabila.
Si daca o gasea cu 30.000 de km in bord se putea foarte bine sa fie reali.
Evident, singurul mod in care poti sa stii asta, este ca proprietarul sa fi facut interventii la masina in reteaua de service-uri Citroen ca sa fie monitorizat kilometrajul in baza de date.
aurelian21
- Localitate: Cluj Napoca
hai ca astea-s deja pareri de "experti" ce sa-ti spun ca c5-ul meu din 2003 are 175.000 si al meu e dat inapoi ? eu am cumparat masina acum 5 ani adusa din franta la 98.000 verificati in reprezentanta si am facut toate reviziile ori la Citroen ori la Mihai Sandor (mai nou la mihai pe premisa ca este de 10 ori mai priceput decat multi din reprezentanta) nu am carte service la ea pentru ca nu am primit nici eu, dar daca mai9ne scot masina la vanzare vrei sa-mi pui ca toata lumea va zice ca am km dati inapoi ? e cea mai mare idiotenie existenta pe lumea asta. Daca este asa atunci ma duc si cumpar o carte service cu 150 de euro cu toate reviziile facute la zi unde trebuie si te mint ca un hot decat sa-ti zic adevarul care l-am spus acum si sa ma trezesc ca ma iei peste picior si-mi scazi pretul cu cateva sute de euro pe premisa direct stabilita ca masina are km dati inapoi.
Legat de dotari masina mea are un nivel de confort dar nu-ti va pusca ce gasesti pe service.citroen.com dupa VIN cu ce are masina de fapt NICIODATA, am adus o gramada de inbunatatiri masinii si toate cu piese de fabrica, asta nu inseamna ca masina mea nu este aproape FULL. ca si exemple ca sa nu zici ca-s modificari de becuri ca i-am pus KIT HID sau mai stiu ce sunt asa. I-am pus Navigatie , i-am schimbat cutia de la automata la manuala, i-am pus faruri XENON ORIGINALE Interior din piele cu scaune incalzite, CD changer si in urmatoarele saptamani urmeaza sa-i pun Trapa
VIN-ul masinii e VF7DCRHZE76476019 sa-mi arati unde scrie in fisa masinii ca are asa ceva si-ti dau nota 10 + daca nu ma crezi te invit oricand la cluj sa vezi masina si-ti garantez ca nici in 300 de ani nu-ti vei da seama ca au fost facute aceste modificari la masina, exceptand cea de cutie de la care au ramas niste fire necuplate din cauza ca cutia manuala nu are computerul ei, dar daca chiar supara pe cineva pot oricand scoate firele acelea din cablaj ca nu e mai mult de 2-3 ore de lucru. Toate modificarile au fost aduse de catre oameni din reteaua CITROEN sau oameni care lucra pe citroen de ani de zile si ma mandresc cu faptul ca au ajuns sa puna mana pe masina mea ca sa o aduca in starea in care e !
http://www.elipsemedia.com/ - webdesign
Intr-adevar, sunt situatii si situatii. Sunt convins ca fiecare dintre noi stim macar un caz in care o masina de cativa ani are km putini.
Eu insumi am un peugeot 308 pe care l-a condus nevasta-mea de nou si care are in 3 ani jumatate vreo 12 mii parca.
Insa si mai tare, am un amic a carui sotie are un matiz din 2005 cu doar 20 de mii.Masina a fost luata de noua.
Problema apare cand cumperi o masina de afara, dar adusa de un roman.
Din pacate, singura modalitate pe care o stiu de verificare, este istoricul masinii in reprezentanta.
marianmarian
- Localitate: cernavoda
Total membri 11832
Cel mai nou membru CezarXsara
