C4 Picasso
Forum de dicutii generale despre Citroen C4 Picaso Âşi Citroen Grand C4 Picasso, dotari, oferte, versus, posesori, etc.
Vasea30
Localitate: Iasi
Masina: Renault Scenis 2, 1.6 b, 2006
Mesajde Vasea30 » Mar 22-Ian-2013 14:12
Imi pare rau sa aud asta :(
de aceea am deschis un topic de rechemari:
http://www.clubcitroen.ro/forum/viewtop ... 571#192571
Iar pe site-ul http://www.theaa.com/allaboutcars/recal ... &makeId=A7 , la sectiunea C4 PICASSO sunt 12 rechemari din 2007 incoace, poate va ajuta cu ceva:
Recall: No. 1 of 12
Recall Ref: R/2009/099
Exact Model: Berlingo, Xsara, Picasso
Description: REAR DAMPER MAY BECOME INSECURE
VIN: VF7******9J087225 to VF7******9N013700
Build Date:
Numbers: 54
Defect: The rear dampers lower fixing bolts may become loose.
Action: Recall affected vehicles to check conformity of damper lower fixing bolt and replace if necessary
Launch Date: 09 October 2009
Recall: No. 2 of 12
Recall Ref: R/2008/111
Exact Model: C4 PICASSO, C8, RELAY III
Description: Vacuum braking assistance may reduce
VIN: VF7******13287355 to VF7******64018484
Build Date:
Numbers: 307
Defect: It has been identified that the check valve within the brake assistance vacuum pump may suffer from a non-conformity which in time may reduce the braking assistance
Action: Recalled vehicles as a preventative measure will have the subject valve replaced. At the same time, certain vehicles will also have the air dosing unit replaced.
Launch Date: 16 July 2008
Recall: No. 3 of 12
Recall Ref: R/2007/109
Exact Model: C4 Picasso
Description: SEAT BELT MAY FAIL IN A COLLISION
VIN: VF7******45002651 to VF7******45075747
Build Date: 05 Sept 2006 to 31 Mar 2007
Numbers: 101
Defect: It has been identified that on some vehicles fitted with electrically controlled seats, in very rare cases, and under certain impact conditions, the front seatbelt may provide a diminished level of restraint.
Action: As a preventative measure, subject vehicles will have the front seatbelt buckles replaced.
Launch Date: 20 July 2007
Recall: No. 4 of 12
Recall Ref: R/2008/107
Description: Risk of partial de-bonding of glass panoramic roof moulding
VIN: VF7******45056022 to VF7******45140279
Build Date:
Numbers: 367
Defect: It has been identified that, in the event of incorrect bonding there is risk of the partial release of the glass panoramic roof moulding, such that it becomes visible to the driver. If the concern is not rectified, in the long term the moulding could detach. It should be noted that there is no risk to the integrity of the sealing of the affected area.
Action: Recalled vehicles will have the bonding of the moulding checked and replaced as necessary
Launch Date: 01 August 2009
Recall: No. 5 of 12
Recall Ref: R/2011/049
Description: ELECTRIC PARKING BRAKE MAY MALFUNCTION
VIN: VF7******45002058 to VF7******45104985
Build Date: 06/07/2006 To 11/05/2007
Numbers: 8230
Defect: It has been identified that due to a nonconformity in one of the operating cables of the Electric Parking Brake (FSE), it is possible that insufficient application (force) will be applied. This could result in only one wheel operating or locked. The drive
Action: Recall all affected vehicles for inspection, repair or if required, the replacement of the cable.
Launch Date: 18 April 2011
Recall: No. 6 of 12
Recall Ref: R/2010/060
Exact Model: C4 Picasso and C1
Description: FRONT SEAT BELT MAY NOT LOCK CORRECTLY
VIN: VF7******9J324087 to VF7******9J346065
Build Date: 02 Dec 2009 to 03 Dec 2009
Numbers: 134
Defect: The front seat belts may not lock in the buckles correctly which will have the affect of the front passengers not being sufficiently restrained in the case of a violent impact.
Action: Recall the vehicles that are likely to be affected to check and where necessary repair the seat belt locking mechanism.
Launch Date: 04 June 2010
Recall: No. 7 of 12
Recall Ref: R/2008/199
Exact Model: C4 Picasso, C2,C3, C3 Pluriel, C4, C5,C6 and Berlingo
Description: WIPERS / LIGHTS/ BATTERY CHARGING MAY BE AFFECTED.
VIN: VF7******67002101 to VF7******45299702
Build Date: 1/2/08 to 14/6/08
Numbers: 6031
Defect: An incorrect engine relay unit may have been fitted. This ECU could deteriorate and cause operating faults and perhaps failure of certain equipment
Action: Recall affected vehicles, check Engine Relay Unit and replace if not correct specification.
Launch Date: 24 December 2008
Recall: No. 8 of 12
Recall Ref: R/2011/018
Exact Model: C4, C4 PICASSO, C8, DISPATCH III
Description: FUEL MAY LEAK
VIN: VF7******AZ033223 to VF7******AY563653
Build Date: 08/07/2010 To 13/10/2010
Numbers: 33
Defect: It is possible that the fuel return pipe may chaff on the diesel fuel filter support in the engine compartment. This can, if not identified, result in a fuel leak.
Action: Recall all affected vehicles for the addition of a protective sleeve to the return pipe.
Launch Date: 22 February 2011
Recall: No. 9 of 12
Recall Ref: R/2010/223
Exact Model: C4, C4 Picasso, C5 & Dispatch II
Description: BRAKING ASSISTANCE MAY NOT PERFORM CORRECTLY
VIN: VF7******13319991 to VF7******9Z012710
Build Date: 21/12/2006 To 27/03/2009
Numbers: 20063
Defect: In very rare circumstances the vacuum pump one way valve may not function correctly which could affect the level of braking assistance.
Action: Recall the vehicles that are likely to be affected to replace the brake vacuum pump one way valve.
Launch Date: 17 December 2010
Recall: No. 10 of 12
Recall Ref: R/2012/026
Exact Model: C4, DS4, C4 Picasso and Berlingo III
Description: SEAT BELT FIXING BOLTS MAY LOOSEN
VIN: VF7******BJ817251 to VF7******BY651672
Build Date: 22/11/2011
Numbers: 64
Defect: The fixing bolts of the front LH and RH seat belt return rail may loosen, and in cases of extreme force break.
Action: The bolts on the left and right- hand sides will be replaced.
Launch Date: 08 March 2012
Recall: No. 11 of 12
Recall Ref: R/2008/163
Exact Model:
Description: Parking brake may be ineffective
Build Date:
Numbers: 9398
Defect: It has been identified that due to a production non conformity in one of the electric parking brake cables, the brake may not hold the vehicle securely on a steep gradient when the parking brake is applied. This will be accompanied by the illumination of the warning lamp and a message saying 'parking brake faulty' on the multifunction screen.
Action: Recalled vehicles will have the conformity of the cables checked and replaced if necessary
Launch Date: 14 November 2008
Recall: No. 12 of 12
Recall Ref: R/2008/133
Exact Model:
Description: Front brake caliper may become insecure
VIN: VF7******45002710 to VF7******45013187
Build Date:
Numbers: 143
Defect: The front brake caliper fixing screws are not to standard (non-conforming) and may slacken
Action: Recall affected vehicles and replace fixing screws with approved type.
Launch Date: 18 September 2008
Doamne-ajuta!
CITROEN C5 CLUB ROMANIA - facebook.com/groups/110645719379127/
Vasea30
Localitate: Iasi
Mesajde Vasea30 » Lun 04-Feb-2013 08:54
De ce modelele C4 PICASSO au un pret asa mic de revanare, de la ~ 6.500 euro :
http://www.autovit.ro/autoturisme/citroen/c4-picasso
Vasea30
Localitate: Iasi
Mesajde Vasea30 » Sâm 09-Feb-2013 08:22
Am vazut acum 3-4 buc de GRAND C4 Picasso , cutie manuala, foarte tentante, pacat ca nu am banutii :(
http://www.autovit.ro/autoturisme/citro ... /?s=p&gear[manual]=manual
mihai ham
Localitate: Valcea
Mesajde mihai ham » Sâm 09-Feb-2013 08:47
Sunt așa ieftine ĂŽn primul rând cĂŁ mai toate sunt aduse din Franța de unde ști și tu cĂŁ au fost luate la licitații ”la pachet” .
Pentru preț samsarii le cautĂŁ pe cele mai rulate cu muuulte sute de mii de km,care apoi sunt dați ĂŽnapoi și mai este și modalitatea de achiziție fĂŁrĂŁ T.V.A.,ĂŁe firme fantomĂŁ,T.V.A. care nu mai e plĂŁtit niciodatĂŁ
De aici prețul ”bombĂŁ”.....dar și mașina tot la fel de bombĂŁ e :D
mihaistan
Localitate: Ploiesti
Mesajde mihaistan » Sâm 09-Feb-2013 09:30
Confirm . Saptamana trecuta am scanat 4 bucati c4 grand picasso , decat 1 a fost ce trebuie ... restul fantome cu peste 200 000 km . An fabricatie 2010 ! asa ca mare atentie !
Vasea30
Localitate: Iasi
Mesajde Vasea30 » Sâm 09-Feb-2013 18:47
Peste 200.000 km in 2-3 ani ? pai, in afara de taxiuri, ce rol ar fi jucat, cu asa kilometraj.....
rezulta ca trebuie sa ne aducem masina direct de afara, pentru a avea o siguranta mai mare...
pacat ca lumea nu se implica mai mult, cu idei, solutii, comentarii pe topicul:
http://www.clubcitroen.ro/forum/viewtopic.php?t=20482
prefer sa dau 10-30 % IN PLUS pentru o masina, dar sa fiu SIGUR ca nu e "manarita" ....
multumesc!
Vasea30
Localitate: Iasi
Mesajde Vasea30 » Dum 10-Feb-2013 08:07
Am aruncat un ochi pe site-ul oficial de masini SH Citroen, au garantie minim 1 an:
http://www.citroenselect.fr/fr/detail/154606
Citroen - GRAND C4 PICASSO HDI 110 FAP MILLENIUM = 9 900 € TTC
Airbags rideaux AV et AR = airbag-uri cortina fata-spate ???
KilomĂŠtrage parcouru 131 740 km
1ère immatriculation 30/12/2009
Énergie Diesel
BoĂŽte de vitesses Manuelle
Garantie Citroen Select 12 mois
Nombre de portes 5
Couleur Gris
RĂŠgion Champagne-Ardenne
NumĂŠro d'annonce FR_020208R_204975
DĂŠpartement Haute-Marne
ABS
ESP
Antipatinage
Jantes Alu
Airbags latĂŠraux avant
Airbags frontaux
Ordinateur de bord
Phares antibrouillard
Vitres avant ĂŠlectriques
Vitres arrière ĂŠlectriques
Radio CD MP3
Verrouillage centralisĂŠ des portes
Filtre à particules
Capteur de pluie et de luminositĂŠ
RĂŠgulateur-Limiteur de vitesse
Allumage des phares automatique
Toit panoramique en verre
Airbag genoux
Verrouillage auto. des portes en roulant
Direction assistĂŠe asservie à la vitesse
Boite mĂŠcanique robotisĂŠe
Clim automatique bi-zones
Volant rĂŠglable en profondeur et hauteur
Frein stationnement ĂŠlectrique automatiq
Aide au dĂŠmarrage en cĂ´te
Pack Urbain
Cum vi se pare anuntul ?
multumesc !
GTaime
Mesajde GTaime » Vin 19-Apr-2013 15:25
Salutare! Din octombrie anul trcut sunt si eu posesor de C4 GRAND PICASSO 1.6 HDI an fabricatie 2008 cutie manuala. L-am cumparat la 107000 km de km, in prezent are putin peste 110000 km, o folosesc mai mult in weekend si in vacante. Pot spune ca sunt foarte multumit pana acum de aceasta masina, imi place foarte tare pozitia la volan si vizibilitatea, interiorul, consumul extraordinar pentru asa volum de masina, si bineinteles spatiul pentru care am si optat atunci cand am luat masina din aceasta clasa. Am mai avut un C5 acum cativa ani, e drept ca era o versiune full extra, mi-a placut la nebunie, C4 Grand e alta clasa si il folosesc pentru altceva, nu se pot compara cele 2 modele. Sa auzim de bine!
Deleu_Dorel
Localitate: Romania, Iasi
Noul Picasso 2013
Mesajde Deleu_Dorel » Sâm 20-Apr-2013 15:07
Imi place foarte mult partea frontala a noului Picasso. La spate e ceva de discutat http://www.automobilen.ro/citroen-c4-pi ... 3-oficial/
DanF
Mesajde DanF » Sâm 31-Ian-2015 23:07
Masina o am si o foloaesc zilnic. Probleme am mai avut dar nu se compara cu schimbat motorul.
Am raspuns la o rugaminte de actualizare.
Spor.
luciano75
Localitate: italia
Mesajde luciano75 » Vin 22-Mai-2015 00:42
salut. m-am oprit de curand asupra c4 picasso de la citroen. imi place f mult designul exterior iar la interior vad ca e incapator pt o familie. as dori insa niste parere in legatura cu cutiile de viteze...nu sint lamurit de optiune....manual sau automatic....nici nu cunosc prea mult despre ele
vreau sa cumpar una de prin 2010-2011 1.6 hdi.....daca imi puteti da ceva sfaturi in legatura cu cutiile de viteze si masina in general
acum am un opel astra h facut la comanda cu sasiu sport, suspensii rigide.....etc
munteanf
Localitate: Simeria
Masina: C4 grand picasoo 2.0 hdi
Mesajde munteanf » Dum 13-Dec-2015 21:37
Salutare prieteni,
din 19 Octombrie sunt si eu proprietarul unui Grand C4 Picasso 2.0 HDI cutie automata an 2007 - l-am cumparat personal din Germania la 160000 Km direct de la proprietar, este masina familiei :) , sunt foarte mandru de masina, o conduc cu mare placere... Problema e ca la denivelari relativ mici se aude un "troncanit" care ma deranjeaza, am fost la un atelier auto (niste cunostinte) si nu am gasit nimic concret, totusi mecanicul mi-a zis ca e foarte posibil sa fie caseta de directie ... (credeti ca e posibil?) ; am intrat aici pe acest portal si am citit postarile ... unele m-au cam "speriat" in sensul ca eu am avut intotdeauna o parere buna despre marca Citroen iar aici am vazut o multime de oameni cu multe probleme si multe nemultumiri. Sunt aici pentru a invata de la cei cu experienta si pentru acumula cunostinte despre aceasta masina de care deocamdata suntem atat eu cat si toata familia foarte multumiti si mandrii si sper sa invat s-o intretin si s-o folosec cativa ani buni (in graba nu imi permit sa cumpar alta masina).
Multumesc anticipat tuturor celor care imi vor raspunde si nu in ultimul rand celor ce au infiintat acest forum.
Sanatate!
Florin Muntean
Citroen Grand C4 Picasso 2.0 HDI
munteanf
Localitate: Simeria
Mesajde munteanf » Lun 14-Dec-2015 00:07
DanF scrie:mie mi s-a intamplat treaba cu motorul in iunie 2012. fara sa dea vreun semn a facut poc, culmea coincidentei, pe la 50-60km/h.
explicatia a fost evident una pe care nu o cred, calitatea motorinei, de parca alte motoare hdi nu mai exista in Romania.
mi-am cumparat un motor reconditionat tot de la Citroen, pe care am dat o caruta de bani, dar macar are garantie 2 ani.
eu consider ca am fost inselat de Citroen si ca utilizator am facut exact ce scria in cartea tehnica. acum mai am masina, pentru ca la cat am cheltuit cu ea nu merita sa o schimb. altfel este o masina care iti ofera foarte mult confort.
sper sa nu mai pateasca nimeni ce am patit eu.
masima este un C4P 2.0Hdi Exclusive productie 2007.
Pana la urma ce s-a intamplat? ce a pocnit? s-a spart / rupt ceva?
Florin Muntean
Înapoi la “Citroen (Grand) C4 Picasso”
    Total mesaje 187841
    Total subiecte 18680
    Total membri 11860
    Cel mai nou membru Christie
