VIN masinii
VIN masinii
vf7rcrhrg76702799 asta e vin-ul masinii . pe unde caut sa cumpar ambreiaj gasesc in paranteza dupa anumite caracteristici RCRHRH in loc de RCRHRG cum am eu . e vro diferenta ??? e posibil sa nu se potriveasca ambreiajul ??? si as vrea si caracteristicile masinii dupa vin va rog . si daca se merita sa iau kit si volanta la mana a doua cu garantie atat timp cat eu vreau sa vand masina . ms
- urzica
- Localitate: Medgidia
Caracteristicile vehiculului
Linie de produs C5 II
Nr. APV/PR 10474 CJ 1 0117
Data de Inceput de Garantie DDG 28.07.2005
OPB A03Z
NRE e2*2001/116*0306*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION SUPERIOARA JOASA PLUS
MOTEUR DIESEL TURBO DW10BTED4 FARA FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EYP - VOPSEA GRI FULMINATOR
TYPE D’HABILLAGE INTÉRIEUR PIELE CLAUDIA "Q1"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS EXCLUSIV
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA SUZUKA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA AC 3300I
JOINT COTÉ PONT GARNITURA PE PARTEA PUNTII AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R16 W NERANFORSAT
ROUE (TYPE) MONTARE ROATA ALIAJ 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
Caroserie Echipamente
PACK LOOK EXTÉRIEUR PACHET LOOK EXTERIOR IN CULOAREA CAROSERIEI
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ENJOLIVEUR ROUE (STYLE) TIP SUZUKA
FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT TRAPA DE PLAFON CU COMANDA ASISTATA SECVENTIALA + SISTEM ANTIPRINDERE
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA + ACUSTICA + REFL + GEAMURI LATERALE STRATIFICATE + SPATE SECURIZATE
Echipament de interior
PACK RADIO / INFORMATION / COMMUNICATION RT3 + AMPLIFICATOR + NAVIGARE COLOR
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SUSTINERE ZONA LOMBARA AUTOMATA
ALARME ANTIVOL ALARMA PENTRU VOLUM + PERMETRU - STANDARD
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE LAC NEGRU
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 1 SERTAR DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE LAC NEGRU
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA ELECTRICA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN TESATURA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN CU INCALZIRE
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
AMPLI-ÉQUALISEUR CU AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMMANDE VERROUILLAGE BLOCARE PRIN SUPRA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
OPB A03Z
Informatii generale
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
Electricitate
Diverse
- urzica
http://www.autokarma.ro/set+ambreiaj/ci ... 50/10151/0
http://www.autokarma.ro/volanta/citroen ... 50/10157/0
http://www.autokarma.ro/set+surub+volan ... 50/10157/0
Volanta la mana adoua bineinteles ca se poate dar trebuie sa se potriveasca, insa daca vrei cu adevarat sa repari masina pune un kit nou. Eu am pus LUK si original pe masina avea tot LUK. De atunci merge perfect.
vin citren c5.2
Buna ziua, as dori si eu informatii despre
C5. II. VF7RCRHRG76748033
Tip motor. R*RHR*/RCRHR*/C5
Ma intereseaza norma euro , in talon apare cred E3 dar dpa cartea tehnica si ccalcule rezulta E4
Emisii CO 158 gr/km
Multumesc
Emisii CO 158 gr/km
Multumesc
calorifer4
- Localitate: Focsani
CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
PUTERE STANDARD
''Norma D (2,3,4,5 sau 6) nu are nici o relevanta pentru legislatia romaneasca. Daca va aduceti masini din Germania (sau alte state care au asimilat norma D) singurul criteriu este acela al datei de fabricatie. Atentie mare DATA FABRICATIEI si nu data inmatricularii, cea trecuta pe talonul strain. Dar nici acest criteriu nu este unul absolut sigur, ci doar orientativ''. Faptul ca masina nu detine filtrul de particule posibil este euro 3 (un lucru foarte bun daca luam in calcul necazurile care apar din cauza FAP)dar datorita perioadei in care sa produs si anul de fabricatie a masinii find 15.05.2006 mai mult ca sigur este EURO4... verifica totusi la RAR in fisele tehnice acest aspect daca norma poate fi incadrata cf. datei de fabricatie dupa 01.2005
CARBURANT MOTORINA
PUTERE STANDARD
Total membri 11832
Cel mai nou membru CezarXsara
